b18c1 swap troubles
b18c1 swap troubles
i am having troubles with my wiring on my swap ive got a 00 civic ex with a 98 b18c1 and i cant match the wiring up are there adapters or anything i can buy to make this a little more simple? or any knowledge would be very appreciated!
New User
https://honda-tech.com/zerothread?id=856396 read through that not exactly your application but should help a little
Re: (japerf1)
I just did a 97 JDM B18C-GSR into an 00 Civic Ex, so almost the same thing. Which harness are you using? Hopefully it's the Civic harness since it requires the least modification. Which plugs are you stuck on?
Re: (notsofastyet77)
your totally ******* lost you can't use an integra harness in a 96-00 civic
read here
http://technet.ff-squad.com/
read here
Re: (sicones)
Sounds like the guy using it before was using it in a 96-98, which I think is way different than the 99-00. Not only is there less/more pins but the pinout is different... I could be wrong but that's something I was told to look out for when I did my swap.
Re: (RedEK9)
Incorrect. 96-98 = 99-00 in terms of # of pins. They're just in different positions. That's why an OBD2b -> OBD2a conversion harness (or vice versa) has a 1:1 mapping of pins.
Edit: For thoroughness, the conversion harnesses are 99% 1:1. There is one 2:1 mapping for the Civic/Integra fuel pump pin difference (one pin off).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones »</TD></TR><TR><TD CLASS="quote">your totally ******* lost you can't use an integra harness in a 96-00 civic</TD></TR></TABLE>
Correct. At least not if you're intending for it to be plug-n-play.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notsofastyet77 »</TD></TR><TR><TD CLASS="quote">i am all wired up but the distributor . the new motor has 9 wires in the plug my plug has 8 whats the extra one</TD></TR></TABLE>
That's a pic of my predicament before. The 9 pin was from the distributor and the 10 (8+2) was from the harness.
Essentially, you have to depin the dist clip from the Integra harness and use it on your Civic harness. Depin both the 8 pin plug and the 2 pin plug on the Civic harness and color match them into the Integra plug. The black on the 2 pin Civic clip is a second ground that you won't need - tape it up and leave it. You should then be good to go.
Modified by EKcivicEX at 11:04 AM 3/9/2007
Chemistry
12-01-2013 02:52 PM
98civicGSR
03-26-2003 04:24 PM
