clutch problem with cable LS tranny with B16a in 89 crx si (clutch not disengaging)
Old May 6, 2006 | 06:12 PM
aaronhume's Avatar
Default clutch problem with cable LS tranny with B16a in 89 crx si (clutch not disengaging)
hello, i spent all day today pulling the tranny in this crx (cable LS tranny) because the clutch was not disengaging. we replaced the through-out bearing and installed a pilot bearing (as there was not one before for some reason) and torqued the pressure plate down as specs require (to 19 lb-ft) in the right sequence... put the tranny back in after greasing everything up, adjusted the clutch cable so the lever was tight and the clutch doesn't do anything. it will start and run fine, but cannot shift once it is on, and if it is started while in gear the wheels will spin and everything but will continue to spin at the same speed when i put in the clutch. any suggestions? ever seen this happen before? thanks!
Old May 8, 2006 | 07:40 AM
aaronhume's Avatar
Default Re: clutch problem with cable LS tranny with B16a in 89 crx si (aaronhume)
bump...
Old May 8, 2006 | 10:23 PM
aaronhume's Avatar
anyone?
Old May 9, 2006 | 04:39 PM
aaronhume's Avatar
??? ideas?
Old May 18, 2006 | 12:42 AM
aaronhume's Avatar
okay well another one of my friends noted that the act pressure plate in combination with the oem clutch may cause an issue... would that be the problem maybe?
Old May 18, 2006 | 01:26 PM
aaronhume's Avatar
bump
Old May 24, 2006 | 10:54 PM
aaronhume's Avatar
ideas anyone? still not working...
Old May 26, 2006 | 11:03 AM
GHETTOBEAST's Avatar
just had this problem happen to me last night on my 91 LS adjusted the clutch cable all they way both ways and still doesnt disengage w/ the clutch to the floor. going to see if i can get it fixed will keep you updated
Old May 27, 2006 | 08:34 AM
Default Re: clutch problem with cable LS tranny with B16a in 89 crx si (GHETTOBEAST)
problem ended up being a bearing in the clutch had to get a new clutch
Modified by GHETTOBEAST at 12:21 PM 5/29/2006
Old Jun 1, 2006 | 10:17 AM
aaronhume's Avatar
did you get a new clutch and pressure plate? or just clutch? and what pressure plate are you using with it? thanks!
Old Jun 9, 2006 | 09:25 AM
i had to get a new clutch the pressure plate is just the oem one
Old Jun 23, 2006 | 05:44 PM
honda_boy_1990's Avatar
having the same problem already tried three different clutch kits and still getting the same resaults
Old Jun 23, 2006 | 05:46 PM
which bearing was the problem
PINKS
12
Jan 14, 2006 06:05 AM
PINKS
Jan 13, 2006 11:17 PM
tegrevboy
Oct 22, 2002 04:11 PM
