A/C issue: 96 EK HB w/ GSR
Old May 6, 2006 | 04:39 PM
enigma94's Avatar
Default A/C issue: 96 EK HB w/ GSR
OK, I'm not sure if this is normal because this is the first honda i've ever owned with a/c (haha i know...) When i'm driving with the a/c on i can feel the a/c cycle on and off and it does it constantly. probably like 2 or 3 times every mile or 2. The a/c blows pretty cold but i think it could be colder.
I went to have it serviced because the condenser is new and i figured the problem was due to low coolent. They filled it up and said it was good to go, but it still does this....
The car is a 96 ek hatchback with a GSR.
any help is appriciated!
Old May 6, 2006 | 07:10 PM
enigma94's Avatar
Default Re: A/C issue: 96 EK HB w/ GSR (enigma94)
TTT
Old May 6, 2006 | 09:40 PM
enigma94's Avatar
anybody?
Old May 6, 2006 | 09:46 PM
strictly.business's Avatar
Banned
could either be your compressor or blower motor. if you think it could be colder, could either need a recharge or needs a new compressor.
Old May 7, 2006 | 12:15 PM
enigma94's Avatar
Default Re: A/C issue: 96 EK HB w/ GSR (strictly.business)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strictly.business &raquo;</TD></TR><TR><TD CLASS="quote">could either be your compressor or blower motor. if you think it could be colder, could either need a recharge or needs a new compressor.</TD></TR></TABLE>
I charged it the other day. Man imma be pissed if its either one of those. It blows hard though so i dont think its the blower motor....
Old May 7, 2006 | 12:20 PM
pdiggitydogg's Avatar
The ac isnt cycling on and off, the fan on the condenser is...which is normal.
Run the car with the ac on @ idle and watch it happen.
Old May 7, 2006 | 09:24 PM
enigma94's Avatar
Default Re: (pdiggitydogg)
I can FEEL it cycle on and off. Like i am sitting there pushing the a/c button on and off. I doubt its the fan that is causing this.
Old May 7, 2006 | 11:28 PM
enigma94's Avatar
Default Re: (enigma94)
bump for answers
Old May 8, 2006 | 03:55 AM
enigma94's Avatar
ttt
Old May 8, 2006 | 06:14 AM
why not try watching it like I suggested
Old May 8, 2006 | 02:05 PM
enigma94's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">why not try watching it like I suggested</TD></TR></TABLE>
Yea, I know the fan goes on and off. But I doubt thats the reason why it cycles on and off. anybody else have any ideas?
Old May 8, 2006 | 02:47 PM
ecahatch's Avatar
Senor Miembro
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by enigma94 &raquo;</TD></TR><TR><TD CLASS="quote">Yea, I know the fan goes on and off. But I doubt thats the reason why it cycles on and off. anybody else have any ideas?</TD></TR></TABLE>
you don't know what it is yet.....so you might as well give it a try.
might be a f'd up harness?......
Old May 8, 2006 | 04:40 PM
enigma94's Avatar
Default Re: (ECAhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ECAhatch &raquo;</TD></TR><TR><TD CLASS="quote">
might be a f'd up harness?......</TD></TR></TABLE>
Yea i'm going to test it out tonight after i change my oil.
Old May 9, 2006 | 02:28 PM
enigma94's Avatar
uppppp
Old May 9, 2006 | 03:02 PM
Falqon's Avatar
common reason for cycling is low refridgerant pressure, probably should find a gauge or something and make sure it's working. Generally when it's running the pressure drops, and in your case too much causing the compressor to shut off, then after it shuts off, pressure rises so the pump starts again, rinse and repeat.
Old May 9, 2006 | 05:09 PM
enigma94's Avatar
Default Re: (Falqon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Falqon &raquo;</TD></TR><TR><TD CLASS="quote">common reason for cycling is low refridgerant pressure, probably should find a gauge or something and make sure it's working. Generally when it's running the pressure drops, and in your case too much causing the compressor to shut off, then after it shuts off, pressure rises so the pump starts again, rinse and repeat.</TD></TR></TABLE>
damn, i hope i didnt get screwd by the guys i had service it. either that or there is a leak somewhere.....
anyboyd have the stock specs on what the pressure should be?
Old May 9, 2006 | 05:30 PM
JDM97EK's Avatar
MAN THERE ARE SOME STUPID PEOPLE POSTING DUMBASS IDEAS! FIRST OF ALL DID YOU KEEP THE CIVIC COMPRESSOR OR DID YOU USE THE GSR? I JUST RECENTLY HAD THE SAME PROBLEM AND THE GSR COMPRESSOR WAS TOO POWERFULL FOR THE SMALLER CONDENSER. ALSO IT WILL ALSO CYCLE LIKE THAT IS THE SYSTEM IS OVERFULL. DID THE SHOP INSTALL DYE INTO THE SYSTEM? THESE ARE THE PRESSURES ON MY SYSTEM HIGH SIDE WAS @200 PSI AND THE LOW SIDE WAS @30 PSI AND IT COOLS TO 42 DEGREES. THE ONLY WAY TO CHECK IT IS TO HAVE A SET OF PROFESSSIONAL A/C GAUGES I THINK MINE COST ABOUT 200 BUCKS FROM MATCO TOOLS. A GOOD START IT TO GET A THERMOMETER AND SEE HOW COOL IT IS ACTUALLY GETTING. THEN YOU CAN START TO ELIMINATE PROBLEMS LIKE THE PRESSURE SWITCH AND SO ON.
Old May 10, 2006 | 03:24 PM
enigma94's Avatar
Default Re: A/C issue: 96 EK HB w/ GSR (JDM97EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM97EK &raquo;</TD></TR><TR><TD CLASS="quote">MAN THERE ARE SOME STUPID PEOPLE POSTING DUMBASS IDEAS! FIRST OF ALL DID YOU KEEP THE CIVIC COMPRESSOR OR DID YOU USE THE GSR? I JUST RECENTLY HAD THE SAME PROBLEM AND THE GSR COMPRESSOR WAS TOO POWERFULL FOR THE SMALLER CONDENSER. ALSO IT WILL ALSO CYCLE LIKE THAT IS THE SYSTEM IS OVERFULL. DID THE SHOP INSTALL DYE INTO THE SYSTEM? THESE ARE THE PRESSURES ON MY SYSTEM HIGH SIDE WAS @200 PSI AND THE LOW SIDE WAS @30 PSI AND IT COOLS TO 42 DEGREES. THE ONLY WAY TO CHECK IT IS TO HAVE A SET OF PROFESSSIONAL A/C GAUGES I THINK MINE COST ABOUT 200 BUCKS FROM MATCO TOOLS. A GOOD START IT TO GET A THERMOMETER AND SEE HOW COOL IT IS ACTUALLY GETTING. THEN YOU CAN START TO ELIMINATE PROBLEMS LIKE THE PRESSURE SWITCH AND SO ON. </TD></TR></TABLE>
I Note sure which compresor was used. I'd assume the stock Dserres since they are chassis specific from what i know. There was no dye installed because i didnt think there were any leaks I guess i should of done it though. I dont have professional gauges so i really cant check the pressure but i will get a thermometer and see what its blowing and go from there....
kast
Sep 11, 2012 12:32 PM
iamalex1212
Oct 11, 2008 11:14 AM
Universal Magnetic
Jan 7, 2007 07:17 AM
lowRIDAH
Sep 2, 2005 08:57 AM
turboscooby
Jun 30, 2005 02:44 PM
