thermo housing ground
Old May 6, 2006 | 03:55 PM
Beau Gotti's Avatar
Default thermo housing ground
where does it go, i know there is supposed to be a ground there, but where does it go, there are no loose grounds anywhere, i can find, but there is a place to ground it at. can i just run a ground to the neg. battery terminal or the fire wall or something
Old May 6, 2006 | 05:26 PM
Hawkze_2.3's Avatar
Default Re: thermo housing ground (Beau Gotti)
Should be right beneath the rad hose....I know mine has coolant all over from the hose leaking a little bit.
Old May 6, 2006 | 06:40 PM
Beau Gotti's Avatar
beneath the rad hose? i see a place above it to put it. and also there are 2 ground wires that goto the side of the thermo housing. is this it?
stocker2shocker91
Nov 8, 2010 11:25 AM
90Rexx
Aug 25, 2009 12:00 PM
JLefevers
Apr 21, 2009 07:10 AM
lunchboxEF91
Mar 7, 2005 02:54 PM
