Big problem and need help ASAP!!!!!!!!!!
Ok this is hard to explain but ill give it my best shot. Im doing a usdm b16 swap in my eg. On both sides of the fire wall there are about three inches of wires coming out. then they plug into the harness. If i were to unplug those would the b16 harness plug into the "three inches?" Also, I have no ECU when i get the swap ill be using the b16 ECU. So will my ex plugs fit into the b16 ECU? Please try your hardest to understand this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi »</TD></TR><TR><TD CLASS="quote">i would use your stock eg harness and just add vtec wires. </TD></TR></TABLE>
A lot easier to just run the Vtec wires then to try swapping harness's
OregonEGHatch
Jul 18, 2006 12:57 PM
smash fascism
Apr 8, 2005 05:39 PM
freeeked
Aug 30, 2003 02:27 AM
