Suspension & Brakes Theory, alignment, spring rates....
Integra LS rear sway bar on 97 civic coupe
Old May 6, 2006 | 09:54 AM
whuynh168's Avatar
Default Integra LS rear sway bar on 97 civic coupe
Anybody know if the 94 integra LS rear sways fit on a 97 civic ex coupe with no problems? Also does the front fit as well? Do i need to purchase anything to make these things work properly, if so, anybody know where to get them cheap? Thanks in advance for the replys.
Old May 6, 2006 | 11:11 AM
Voyage34's Avatar
Default Re: Integra LS rear sway bar on 97 civic coupe (whuynh168)
yes it fits, you need the mounting brackets from an em1... those are a flat mount to fit your subframe rather than the stepped subframe of the tegs.
also, you will need either si or other helm-joint endlinks since the ls ones dont line up with your stock mounting location, too narrow by some distance, i dont recall what exctly, about 1 1/4" or so iirc. another option, instead of finding new endlinks is to divide that distance in half and drill new equidistant holes in the lca. that decreases the measured stiffness of the bar by a few percent, but it wont really be noticable.
Old May 6, 2006 | 11:44 AM
whuynh168's Avatar
Default Re: Integra LS rear sway bar on 97 civic coupe (Voyage34)
thanks!
rarrior23
Nov 28, 2008 12:16 AM
dj theoretic
Oct 30, 2008 08:29 AM
NuclearB18B
Feb 4, 2003 08:59 PM
sa21199
Jan 4, 2003 06:48 PM
