topped out
Old May 6, 2006 | 01:59 AM
noopsITR's Avatar
Default topped out
i have a 98+ type r in my integra and had the chance to let it loose. but at around 122 mph the speed limiter kicked in and wouldnt let me go any faster. i was at 7000 rpm. anyone know how to get rid of the limiter? thank you.
Old May 6, 2006 | 02:20 AM
Reid's Avatar
Global Moderator
Default Re: topped out (noopsITR)
There is no speed limiter.
A stock ITR will bounce the revlimiter in 5th gear.
Old May 6, 2006 | 02:50 AM
noopsITR's Avatar
i was in 5th. then how do i get rid of the rev limiter?
Old May 6, 2006 | 03:59 AM
Nishant's Avatar
Default Re: (noopsITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by noopsITR &raquo;</TD></TR><TR><TD CLASS="quote">i was in 5th. then how do i get rid of the rev limiter?</TD></TR></TABLE>
you have a R ecu?
Old May 6, 2006 | 05:37 AM
Reid's Avatar
Global Moderator
Why would you want to get rid of the rev limiter?
Are you using a JDM ITR ECU and leaving out that very important piece of information? JDM ECU's have a speed limiter.
Also, at which race track are you hitting these kind of speeds?
Old May 6, 2006 | 05:55 AM
George Knighton's Avatar
H-T Order of Merit
Default Re: topped out (Reid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">There is no speed limiter.
A stock ITR will bounce the revlimiter in 5th gear.</TD></TR></TABLE>
Just verifying what Reid says. A USDM ITR with the stock computer will usually be able to touch the limiter in fifth gear.
It might take a while, and you might not have a track with a straight long enough to do it, but it <u>will</u> do it.
If you have put a JDM motor in your ITR and used the JDM computer, then, of course, you will be subject to the JDM limitations on speed. You would have to use a different computer to get rid of the limit.
Try the user "Kenji" and see if he has an idea about this. He sells relatively cheap, but well thought out plug-in computer chips.
Old May 6, 2006 | 06:18 AM
ITR1227's Avatar
Buy a Formula 1 engine.
Maybe 19,000 rpms will be enough for you.
Or you could change your gears. Car might accelerate slowly but you could probably squeek out 160 mph.
Or do both and you could bounce off the rev limiter at 19 and top out at 200 plus!
Old May 6, 2006 | 06:33 AM
1GreyTeg's Avatar
Default Re: (Reid)
Also, at which race track are you hitting these kind of speeds?</TD></TR></TABLE>
I'm curious as well.
Old May 6, 2006 | 06:37 AM
b19coupe's Avatar
Default Re: (Reid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">Also, at which race track are you hitting these kind of speeds?</TD></TR></TABLE>
My guess is the track known as Interstate 15
Old May 6, 2006 | 06:46 AM
JjuuN R's Avatar
Default Re: (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">
My guess is the track known as Interstate 15 </TD></TR></TABLE>
my guess as well...
Old May 6, 2006 | 06:47 AM
Batoutahell's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">My guess is the track known as Interstate 15 </TD></TR></TABLE>
C'mon guys, I'm sure it was on a race track. If people haven't figured out by now not to bring highway racing or canyon carving stories to this forum, they absolutely deserve an e-slap upside the back of their head.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by noopsITR &raquo;</TD></TR><TR><TD CLASS="quote">i have a 98+ type r in my integra and had the chance to let it loose.</TD></TR></TABLE> A type R motor in a non-type R? My money is also on the ecu.
Old May 6, 2006 | 06:51 AM
noopsITR's Avatar
Default Re: (ITR1227)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR1227 &raquo;</TD></TR><TR><TD CLASS="quote">Buy a Formula 1 engine.
</TD></TR></TABLE>youre an *******, if you dont have an answer then kick rocks buddy.
Old May 6, 2006 | 06:53 AM
ITR1227's Avatar
Ok, Maybe you and your street racing buddies can figure out how to get rid of your rev limiter together!
Old May 6, 2006 | 06:55 AM
noopsITR's Avatar
yeah, its the jdm ecu. i have it in a 2000 itr. thanks guys that posted with a non smart *** remark.
Old May 6, 2006 | 06:57 AM
noopsITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR1227 &raquo;</TD></TR><TR><TD CLASS="quote">Ok, Maybe you and your street racing buddies can figure out how to get rid of your rev limiter together!</TD></TR></TABLE>
arent you missing tea time? never said i was street racing.
Old May 6, 2006 | 08:13 AM
H-T Order of Merit
arent you missing tea time? </TD></TR></TABLE>
Uh....
Why... Yes. Yes, I am.
Old May 6, 2006 | 09:19 AM
808dc2's Avatar
Default Re: (neo_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">Uh....
Why... Yes. Yes, I am.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo_ &raquo;</TD></TR><TR><TD CLASS="quote">Can I come?</TD></TR></TABLE>
Tea for two?
Old May 6, 2006 | 09:35 AM
dc2r01's Avatar
Noops; Iv had my car at 150+mph with a few hundred rpms left to go.
STock
Old May 6, 2006 | 10:48 AM
Haleiwa-Brando's Avatar
arent you missing tea time? never said i was street racing.</TD></TR></TABLE>
122mph....hmmmm. Stock Type-R's will not do that in the 1/4 mile, so this wasn't done at a drag strip. I don't see that kind of speed being done on a closed course in a stock Type-R. Definately not at a HPDE or Auto-X. I'm guessing I-5 race course too
Old May 6, 2006 | 11:15 AM
1GreyTeg's Avatar
Default Re: (Haleiwa-Brando)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">
I don't see that kind of speed being done on a closed course in a stock Type-R. Definately not at a HPDE</TD></TR></TABLE>
then Joor driving too slow
It's more than possible at several of the tracks we drive, IE VIR & Watkins Glen.
Old May 6, 2006 | 01:56 PM
Default Re: (1GreyTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">
It's more than possible at several of the tracks we drive, IE VIR & Watkins Glen. </TD></TR></TABLE>
I'm sure it's possible. It's been done. When I made that comment I was looking at his location under his screen name. He's East, South-East of L.A. I was thinking of the tracks around L.A. that have enough room to get an R topped out in 5th. Maybe Buttonwill *shrug. Configurations 15, 16, 26 and 28 look do-able maybe.
Old May 6, 2006 | 02:01 PM
Reid's Avatar
Global Moderator
Default Re: (Reid)
Answer or ban.
Old May 6, 2006 | 02:28 PM
1GreyTeg's Avatar
Old May 6, 2006 | 03:04 PM
Chris F's Avatar
Default Re: (Reid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">Answer or ban. </TD></TR></TABLE>
The moderator of the ITR forum Reid is one of the worse moderator I have ever seen on the internet and I've been online for like 14 years
chris r sheppard
10
May 24, 2010 10:10 AM
KDvtec5757
Jul 1, 2008 07:30 AM
Singlecam4dr
Jan 27, 2007 11:50 AM
seer
Honda Civic (2006 - 2015)
Jul 16, 2006 07:43 PM
bseries_beast
Dec 30, 2004 02:15 PM
