What do you think happened? (tranny related)
Old May 5, 2006 | 09:00 PM
TurboGoKart's Avatar
Default What do you think happened? (tranny related)*PICS*
I was getting ready to launch, preloaded the drivetrain, and took off (only at about 4k, not using a 2 step, so 0lbs of Boost), didnt get very far at all before I heard a small pop. It wasnt very loud, but after that happened, I couldnt drive anywhere. I can put the car in gear, let the clutch out, and nothing happens. It still idles the same as it does when it is out of gear. Also, after I called a friend, we put the car up on jackstands, and did the same thing - put it in gear, and let out....nothing. Axles didnt turn. My friend said he thought I may have snapped the pinion gear? Oh yeah, you can push the car fine when it's in gear too. Acts just like it does when it's out of gear. Also, when it popped, there was no grinding whatsoever. Just one clean pop and then it wouldnt work anymore.
RPS 6 puck sprung, 1750lb pressure plate, and Clultchmasters lightweight flywheel. Stock axles. Stock Z6 tranny. D16Z6, fully built.
Any takers as to what popped in the tranny before we pull it apart? I've got one who said the pinion gear broke.
Modified by TurboGoKart at 5:00 PM 5/8/2006
Old May 5, 2006 | 09:32 PM
bracket 4 life's Avatar
Default Re: What do you think happened? (TurboGoKart)
could be a blown differential
Old May 5, 2006 | 09:36 PM
DOMKID's Avatar
Default Re: What do you think happened? (infamousCW-hatch)
any metal chunks in your tranny fluid? could be your clutch? did you smell burnt clutch when you heard the "pop"?
Old May 5, 2006 | 09:43 PM
Default Re: What do you think happened? (Felix.)
Didnt smell anything burnt, and dont know about the chunks in the tranny fluid, but there was no grinding at all.
It was basically - revs to 4k, preload, laun...pop. Tha'ts it.
Old May 5, 2006 | 10:23 PM
pull the axles and look in the diff for problems
Old May 6, 2006 | 05:30 AM
Blown90hatcH's Avatar
More than likely you broke the final drive(ring and pinion) or an axle.
Old May 6, 2006 | 05:55 AM
speedworks's Avatar
Default Re: What do you think happened? (Blown90hatcH)
make sure the axles did not back out of the tranny
Old May 6, 2006 | 12:34 PM
99blackcivicSi's Avatar
Default Re: What do you think happened? (speedworks)
passenger side axle probably popped out of the trans check that first if not then look further into it with the diff and see if anything is wrong internaly
Old May 6, 2006 | 04:17 PM
Hybrid_Coupe's Avatar
everytime ive seen someone that broke a final drive, the dif would lock and release and make the car hop, or make a horrible popping sound...it sounds to me like he broke an axle
Old May 6, 2006 | 06:10 PM
Default Re: (Hybrid_Coupe)
But even if I only broke one axle, why will it absolutely not go anywhere with it in gear?? Or is it acting like a true open diff, and spinning just that one side?
Haha, or maybe I popped both axles.
Old May 6, 2006 | 06:14 PM
86si's Avatar
Default Re: (TurboGoKart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboGoKart &raquo;</TD></TR><TR><TD CLASS="quote">But even if I only broke one axle, why will it absolutely not go anywhere with it in gear?? Or is it acting like a true open diff, and spinning just that one side?
Haha, or maybe I popped both axles. </TD></TR></TABLE>all it takes is 1 axle and it won't move at all
Old May 6, 2006 | 06:56 PM
Default Re: (86si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 86si &raquo;</TD></TR><TR><TD CLASS="quote">all it takes is 1 axle and it won't move at all</TD></TR></TABLE>
Really? Hm. How would that work though, even if the other axle is still good?
Old May 6, 2006 | 07:58 PM
h22 civic's Avatar
input shaft or axel look inthe timming light part of the trannny and see if everthing is moveingy
Old May 6, 2006 | 08:14 PM
Default Re: (h22 civic)
The timing light part of the tranny? Can you expand on that. I dont know what you're talking about.
Old May 6, 2006 | 08:47 PM
Antilag's Avatar
I think its an axle, I have a quaife and when i broke axles it will not go anywhere. Check your axles. passenger side first.
Old May 6, 2006 | 08:50 PM
DOMKID's Avatar
Default Re: (9sech22civic)
why is he able to put the car in gear and release the clutch without the motor shutting off?
Old May 6, 2006 | 08:53 PM
MrParks's Avatar
Default Re: (Felix.)
could be the selector in the trans too we broke a couple of them
Old May 6, 2006 | 08:59 PM
That's where I heard the pop from, and I have some grease slung out from the CV boot.
I just dont understand how 1 popped axle will make nothing happen!
Old May 7, 2006 | 05:23 AM
Antilag's Avatar
10-1 you found your problem there, just pull that axle and check it.
Old May 7, 2006 | 04:18 PM
Will do this tomorrow. I'll let you know how it turns out.
Old May 7, 2006 | 05:06 PM
.RTErnie's Avatar
the differential is a torque multiplier...so when you get slip on one side...it transfers the force to the other side. Anything times 0 is still zero...thus why your car wont move with 1 broken axle.
Old May 8, 2006 | 12:13 PM
h22 civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboGoKart &raquo;</TD></TR><TR><TD CLASS="quote">The timing light part of the tranny? Can you expand on that. I dont know what you're talking about.</TD></TR></TABLE>
the rubber plug you pull out on your tranny to use ther timming light on you should see in their with light
Old May 8, 2006 | 01:08 PM
B18C4-T's Avatar
The accords use the rubber plug to set timing off of the flywheel, civics and integras don't have the plug because you set the timing off of the crank pulley. Larry
Old May 8, 2006 | 02:50 PM
Well, this might explain why I wasnt going anywhere. I pulled the axle today to find this:
That's the differential that the axle splines go into when you put the axle into the tranny, right? Yeah, it's toast.
So it's time for a new tranny, or get an OBX put in this tranny. I have to figure out which to do.
Old May 8, 2006 | 03:29 PM
scansel912's Avatar
Damn, what tires were you using?
