Piston/valve clearance B18/b16
Old May 5, 2006 | 08:45 PM
Ruben19's Avatar
Default Piston/valve clearance B18/b16 >>>>PROBLEM<<<<<
my set up is
Stock b16a2 head
B18c1 block
Blox type b cams
It has 11.5:1 JE piston
The problem is that i intalled a spoon 2p head gasket but when the engine is at top dead center and i turn the exhaust camshaft it wont turn all the way. I think the valve are hitting the pistons. but if i turn the intake camshaft it turns normal.
Before i just to have a cometic head gasket i think it was .30mm and this spoon is probably .20mm
So you think the spoon headgasket is causing my valve to hit the pistons.
I will buy a stock head gasket tomorrow.
is the stock head gasket .30mm
Old May 6, 2006 | 12:02 AM
Ruben19's Avatar
i set the timing and the engine rotates good. it wont lock anymore.
my cam gears are set up (0,0) until i get my car tune.
im just woundering how people with 12.5cr handle this problem.
im only running 11.5
im sure i will be ok
Old Jun 19, 2006 | 08:04 AM
2 0 3's Avatar
Default Re: (Ruben19)
if your turning one cam at a time. eventually your valves are going to touch intake to exhaust, especialy if they are locked into vtec. both cams must be rotated together. If you already did this, wich it i beleive you did. you may have bent valves. i learned that the hard way once.
is the motor runnin yet ?
JDMEMone
Sep 7, 2010 07:47 PM
AllMotor12s
32
Aug 15, 2007 03:25 PM
Amped
Aug 30, 2006 02:52 PM
HamiltonRex
Mar 2, 2006 06:28 PM
275Performance
Apr 26, 2005 03:05 PM
