half rad install
hey, im about to purchas a civic half rad for my 5th gen and also new hoses, and just wanted to know wether i need a hose kit (samco) for a prelude or a civic? anyone with a half rad installed if u could help me out that would be great. thanks
I used Prelude hoses but I cut a short length of Civic hose to go around the nipple on the radiator before the Prelude hose. Make sense??
--->https://honda-tech.com/zerothread?id=1189079
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 »</TD></TR><TR><TD CLASS="quote">I used Prelude hoses but I cut a short length of Civic hose to go around the nipple on the radiator before the Prelude hose. Make sense??
--->https://honda-tech.com/zerothread?id=1189079</TD></TR></TABLE>
yea.. using part of the civic hoses makes sense...
quick question though: Are you still running w/ one lower radiator support or did you manage to put a second one there?.. b/c I was woundering if it was necessary to add the second one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TruNinja619 »</TD></TR><TR><TD CLASS="quote">
quick question though: Are you still running w/ one lower radiator support or did you manage to put a second one there?.. b/c I was woundering if it was necessary to add the second one.</TD></TR></TABLE>
I haven't had any problem with the one rad mount. The upper hose puts tension on the rad and pushes it against the rad support where the foam is.....so it's pretty sturdy.
I fabricated a second bracket with just a bent piece of aluminum (two bends) that I drilled a hole in for the radiator to fit through. It's worked fine for several years.
