200 whp possibilities with this setup?
Old May 5, 2006 | 07:37 PM
ORANGE EF's Avatar
Default 200 whp possibilities with this setup?
i hve a 00 gsr swap in my ef hatch. the motor is 100% internally stock. i want to rebuild it myself (first timer) but i want to use all oem parts to make things easier for me. i hav a set of ctr cams and .25 os p30 pistons and i will be using a spark racing header. the car will be converted to obd1 and tuned on chrome pro. do you guys think its possible to hit the 200 whp mark by have a decent head port, opening my skunk 2 mani and porting it, use a bigger tb 65-70mm?, and using a velocity stack intake? is 200whp too much to ask for?
Old May 5, 2006 | 10:07 PM
RaceCarRyne's Avatar
Default Re: 200 whp possibilities with this setup? (ORANGE EF)
search.. 100 ppl have done this already.. and good lukc wiht 200 whp
Old May 5, 2006 | 10:59 PM
allmotormatt's Avatar
Default Re: 200 whp possibilities with this setup? (DC2jdmIntegra)
ok this is just my opinion i think that if you dont hit 200whp it will be the cams and the header if you sold the cams you would have a good chunk to put toward better cams and if you get a good header like the toda you should be able to do it i say the toda because i like them alot and i think with your setup it would be a good match
Old May 6, 2006 | 01:50 PM
ORANGE EF's Avatar
bump
Old May 6, 2006 | 05:31 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: (ORANGE EF)
possible but not very likely. You will need some better hardware that what you have.
allmotor1313
Nov 2, 2007 07:02 PM
jvtec95
20
Oct 17, 2006 10:05 PM
Eg_TypeR
14
Aug 30, 2006 03:47 PM
Beau Gotti
13
Feb 11, 2006 01:37 PM
adro2333
22
Jun 18, 2004 10:38 AM
