Wiring harness question...
Old May 5, 2006 | 07:28 PM
B16A3Civic*Eg's Avatar
Default Wiring harness question...
Im doing an ls swap into my civic. My harness is wired for vtec. Can i still use that harness and will the civic harness work with the ls ECU?
Thanks
Old May 5, 2006 | 07:52 PM
JDMdamian95's Avatar
Default Re: Wiring harness question... (b18*EG*Sleeper)
I did a ls swap in my eg and i used the ls harness. The ecu will work but it has to be obd1. I don't think you can use the stock engine harness. My friend tryed using it and didn't plug in.
Old May 5, 2006 | 07:55 PM
hatchi's Avatar
you can still use your harness. it wont throw a code because you will be using a non vtec ecu
Old May 5, 2006 | 07:58 PM
O RLY's Avatar
Default Re: Wiring harness question... (hatchi)
LS VTEC swap...problem fixed.
Old May 5, 2006 | 08:00 PM
My friend was doing a swap an his 93 hatch. He was trying to use his stock cx harness an a 97 ls engine and it would not plug in.
Old May 5, 2006 | 08:01 PM
What year is the ls engine?
Old May 5, 2006 | 08:26 PM
Default Re: Wiring harness question... (O RLY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O RLY &raquo;</TD></TR><TR><TD CLASS="quote">LS VTEC swap...problem fixed.</TD></TR></TABLE>
I dont know what i need for that....if i did i would probably do that. What should i get for a head. I would probably get a b16 head but i dont know what i need besides that. If you could give me a list that would be awesome!
bettsbanger
Feb 2, 2009 03:07 PM
fwdlooser93eg
Jul 13, 2006 05:08 PM
B16A3Civic*Eg
May 8, 2006 10:17 AM
TheLastSpartan
Oct 14, 2005 09:47 AM
89JDMcrx
Nov 12, 2002 09:34 PM
