without AC, how do you survive?
Old Apr 10, 2002 | 05:24 AM
citanest's Avatar
New User
Default without AC, how do you survive?
For those of you who do not have AC. As a daily driver, what do you do on a rainy foggy day? All the windows fog up within seconds, and nothing help. Can't open the windows because of the rain. What do you do?
Old Apr 10, 2002 | 05:28 AM
DutchITR1689's Avatar
Default Re: without AC, how do you survive? (citanest)
Stop the car. Dry all the windows with a towel and continue the trip....
BTW I have AC....
Old Apr 10, 2002 | 05:30 AM
sackdz's Avatar
I just ripped out my A/C. I have a question I probably should have asked before I did it:
Does the defog/defrost work just as effective in a car with a/c off then a car with no a/c?
I never used the a/c to defog, and it was bearable in a hard rain. Will it be the same?
Old Apr 10, 2002 | 05:31 AM
Dropspeed's Avatar
Mine is not a daily driver but I have driven it in the rain. Vents pointed at side windows, blower motor on high, work fine, no problems. If I lived in Seattle it might be a problem. The hot humid days are the problem. Everytime I think about a/c I picture this heavy *** box in my basement with all of the a/c components and I feel better that the weight is not in my car
Mattj
[Modified by Dropspeed, 9:32 AM 4/10/2002]
Old Apr 10, 2002 | 05:34 AM
Default Re: without AC, how do you survive? (Dropspeed)
How heavy was that box. I'm thinking about removing it after the summer......
Old Apr 10, 2002 | 05:50 AM
Dropspeed's Avatar
Default Re: without AC, how do you survive? (EuroITR1689)
I just weighed it on my trusty "certified" bathroom scale: 39pds of a/c equipment. Lines, compressor, condensor, wiring, brackets.......everything except the Evaporator behind the dash.
Mattj
Old Apr 10, 2002 | 05:53 AM
You left the evaporator in the car? How hard is it to remove that?
Did you let the gasses escape just in the atmosphere? That's not completely legal and healthy for us you know.....
Old Apr 10, 2002 | 05:57 AM
Dropspeed's Avatar
I put my mouth over the line and inhaled j/k I worked at a dealer at the time and had a tech evac the system.......all good and legal. I just looked again at the evaporator yesterday, I don't know how hard it is but its not something I feel like doing yet.
Mattj
[Modified by Dropspeed, 9:57 AM 4/10/2002]
Old Apr 10, 2002 | 06:39 AM
Dr Pooface's Avatar
Defrost
Fan on 2
Heat on medium
I've never really had a problem. Early recognition and fast responce is the key.
Old Apr 10, 2002 | 06:42 AM
Rory Breaker's Avatar
Default Re: without AC, how do you survive? (Ddub)
Just use the defroster and set the temp around medium. Blast as strong as you'd like.
AC =
Old Apr 10, 2002 | 06:56 AM
NeXtLeVeL_TyPe_R's Avatar
i just took out my AC last week.. i dunno how i will fare this summer but last summer i never used it once.
Question on the de-install... The bracket that was holding the AC pump to the block....what did you guys do with that. Remove or not remove???
Old Apr 10, 2002 | 06:58 AM
Dropspeed's Avatar
Default Re: without AC, how do you survive? (NeXtLeVeL_TyPe_R)
That is an engine mount.......I would highly recommend you do not remove it.
Mattj
Old Apr 10, 2002 | 07:00 AM
Replace it with the JDM aluminium version!!!
Old Apr 10, 2002 | 07:20 AM
BoM's Avatar
BoM
Mattj
where does that mount to?
i never noticed anything there?
Old Apr 10, 2002 | 07:32 AM
killingtime's Avatar
Default Re: without AC, how do you survive? (BoM)
How much does a removed AC system weigh? Ive always wondered why folks take $500 of their resale value off the car... for what 30 pounds, maybe?
Hybrid / track cars I can understand, but AC is critical in some places, I sure missed it in a 91 CRX Si in El Paso, TX summer... and enough Type R buyers added it as a dealer installed option in the US in 97-98 that it came standard in 00-01
Demian
Old Apr 10, 2002 | 07:35 AM
ITR-01-0977's Avatar
New User
Until my R is no longer a daily driver I'm going to have to keep the AC....summers reach 125 degrees here in AZ and it just gets too hot for longer road trips. Back east if you had no AC in the rain, the defroster on full blast and the temp set in the middle would usually take care of it.....you could always get some of those plastic window gutter thingies that allow you to take your window down while its raining...I believe there was a post about them yesterday.
Old Apr 10, 2002 | 07:36 AM
Type Goch's Avatar
New User
how would we do without this here in the West Coast?
Old Apr 10, 2002 | 07:46 AM
Cosworth's Avatar
Default Re: without AC, how do you survive? (Type Goch)
It's a must for the dirty south & FL.
Imagine 120+ deg in-car temp + 100% humidity... sure, you can get by, but your car will stink like your armpit! Not worth the trouble unless it's your track car.
Old Apr 10, 2002 | 07:54 AM
tecnic1's Avatar
Anyone know the part number for the bridge to replace the evap with? I really want to get that thing out of my dash.
Old Apr 10, 2002 | 08:10 AM
PM-Performance's Avatar
Default Re: without AC, how do you survive? (tecnic1)
im taking mine fully out. i havent had it working since a couple months after i got it .
one of thelines got fucked up so i just clipped the belt and wil fully take it out in like a week or so .
but you can survuve without it and that friking compressor is like 40lbs. besides all the other **** in there for it .
fogging is a bit of a bitch , but its bearable.
Old Apr 10, 2002 | 08:35 AM
typer_801's Avatar
DD for almost three years now and 45K miles. Trick is early detection and action to keep it from getting too bad. I've also had some good luck with Rain-X anti-fog. Kind of a pain to put on, but worth it in the spring and fall with we tend to get more rain. And yes, it's hot as hell in the summer w/o AC!
Old Apr 10, 2002 | 08:36 AM
mikeSONICGSR's Avatar
Default Re: without AC, how do you survive? (itr206)
I have it, but dont ever use it, im planning on just taking it out.
My GF and mom is the only ones that ever want to have it on, I just like cruisin with the windows, the FOG sux, but I just deal with it.
Old Apr 10, 2002 | 08:49 AM
sackdz's Avatar
Calling Mike K
Hey you guys who've removed yours how did you plug the lines at the firewall into the evap? Anyone come up with anything better than balled up saran wrap and duct tape? olo.
Old Apr 10, 2002 | 08:58 AM
Willard's Avatar
For those of you who do not have AC. What do you do?
the past 5 cars (4 Volvo's and a GMC pickup) did not have working a/c (Sweden does not need it that much)
..so I am use to not having it.
I very rarely use the a/c on the ITR.. but when I do it is for window de-fogging or sweat prevention.
Willis
Old Apr 10, 2002 | 09:00 AM
Willard's Avatar
Default Re: without AC, how do you survive? (sackdz)
anything better than duct tape? olo.
tape is your friend.
there is no plug for the Civic's w/o a/c.. they simply did not have the hole punched in the firewall.
Will
-who has Volvo plugs for his non-ac'ed '79
