Fuel level reading problems
Old May 5, 2006 | 05:46 PM
EFSiR's Avatar
Default Fuel level reading problems
Recently, my fuel level reading stays at FULL and keeps rising over F reading untill there is a what seems like a discharge of electricity on my cluster as all the lights light up momentary, (turn signals, ...) and then it comes down. But shortly after that it keeps climbing up over the F mark.
Any ideas what's happening?
TIA
Old May 5, 2006 | 07:20 PM
Ross 2.0's Avatar
In a Junkyard near you.
I bet you have a bad ground somewhere. Have you done any modifications lately?
Old May 5, 2006 | 07:46 PM
EFSiR's Avatar
Default Re: (MooGoCow3)
I better tell the whole story.
This problem started right after my radar detector plug got busted (fell apart) in the ashtray accessory +12V port. The plug came apart and a part of metal fell into the +12 V and the most bizzare part is that shorting cased the "truck open" light to come on the cluster. Literally, I was driving with my finger in the port trying to get that metal piece out and the light kept on coming on.
At first, this was causing the clock to reset to 12V but eventually this blew one fuse (clock, int. lights) but after changing the fuse, lights and clock are back on, but the fuel level is not working properly. Hmmmm.
Old May 5, 2006 | 09:31 PM
Pee Wee's Avatar
Default Re: (EFSiR)
i dont know what to tell you, but when the fuel gauge stays at full it usually means you broke it
uptownx24x
Aug 11, 2011 07:11 PM
chriszal1
Jun 16, 2011 08:19 AM
mickeey
Mar 11, 2009 07:18 AM
DoWnfall
Nov 9, 2008 08:33 AM
