99 ACCORD REMOTE
Old May 5, 2006 | 05:29 PM
aZnPIGbOi's Avatar
Default 99 ACCORD REMOTE
i just bought a remote off ebay.. and i already programmed it, etc. but the trunk button doesnt work.
it only works if i hit the unlock button and THen right after that i hit the trunk button.. anyone know how i can fix this?
Old May 5, 2006 | 05:36 PM
philadd's Avatar
Default Re: 99 ACCORD REMOTE (aZnPIGbOi)
Strange...
First, if you haven't already, try reprogramming the remote again.
It's also possible you received a remote that was not for your car.
Old May 5, 2006 | 05:39 PM
aZnPIGbOi's Avatar
its 6 Gen 98-02 my car is a 99
Old May 5, 2006 | 05:48 PM
philadd's Avatar
I'm not arguing that part.
The Accord was NOT the only one to have that remote. From what I understand, there was also a slight change in the way the keyless remote system worked half way through the generation, although I've never confirmed it.
Just because the casings are the same doesn't mean that the internals are. The extra remotes at my dealership were very specifically divided into groups, because they would not work correctly with certain other cars.
Old May 5, 2006 | 06:37 PM
Ross 2.0's Avatar
In a Junkyard near you.
Is your car an LX with acessory keyless entry?
Old May 5, 2006 | 07:32 PM
aZnPIGbOi's Avatar
Default Re: (MooGoCow3)
philadd
OHH i seee hrm.. my car is ex. yeah i opend up both of the remotes.. the internal stuff isnt all exactly alike. maybe thats why?
Old May 5, 2006 | 07:35 PM
Ross 2.0's Avatar
Compare the numbers on the back of the remotes
Old May 5, 2006 | 08:00 PM
philadd's Avatar
Default Re: (aZnPIGbOi)
Well, I can tell you this... Most eBay sellers will just look and see if it looks like the one for an Accord, in which case, this one does. If you can't get these to work correctly, you should try contacting the seller. Many of them will be willing to ship you another set, as long as you send the ones you have back to them as well. The only problem is that you might have the same problem with the next set.
Danny.T
Jun 24, 2011 07:06 AM
romes591
Audio / Security / Video
Mar 11, 2008 02:03 PM
Shaun_
Mar 5, 2007 09:31 AM
harryg
Jan 26, 2006 05:34 PM
