Need to replace fuel pump in accord where teh heck is it?
You were right BLKFLSH
1. Relieve the fuel pressure (see page 11-96).
2. Block front wheels. Jack up the rear of the car and support with jackstands.
3. Remove the drain bolt and drain the fuel into an approved container.
4. Disconnect the 3P connector in the trunk or the cargo area.
5. Remove the evaporative emission (EVAP) two way valve cover and fuel hose protector.
6. Disconnect the hoses.
CAUTION:
When disconnecting the hoses, slide back the clamps, then twist hoses as you pull, to avoid damaging them.
Clean the flared joint of high pressure hoses thoroughly before reconnecting them.
7. Place a jack, or other support, under the tank.
8. Remove the strap bolts and let the straps fall free.
9. Remove the fuel tank.
NOTE: The tank may stick on the undercoat applied to its mount. To remove, carefully pry it off the mount.
10. Install a new washer on the drain bolt, then install parts in the reverse order of removal.
CAUTION:
Ooooo, step by step instructions, cool.
but I don't think he has the Helm manual (to turn to page 11-96).
Relieve fuel pressure by loosening bolt on the fuel rail. Use a rag to catch fuel.
It's Honda's network pretty much. It gives me just about every peice of info I need for hondas. Electrical manuals, service news, service bullitens, service manuals.... the list goes on
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLKFLSH »</TD></TR><TR><TD CLASS="quote">Sounds great man, how do I get in? Hahaha.
You dont, it's a restricted club. LOL
</TD></TR></TABLE>You dont, it's a restricted club. LOL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">
Somehow I knew that would be the case. It's not fair. Bohoohoo
1baddcivicsi
Apr 28, 2010 11:32 AM
