cx motor into 93 dx throwing code 4 but cant find a plug to plug it up
Old May 5, 2006 | 04:04 PM
lshatch1.8's Avatar
Default cx motor into 93 dx throwing code 4 but cant find a plug to plug it up
im throwing code 4 CKP - crank position sensor im using the cx harness w a cx motor into a dx i cant find a plug to plug it into... can anyone help? i looked on the dx harness and cant find the clip eaither...
Old May 5, 2006 | 04:16 PM
honda_civic1's Avatar
ok so i see that your car doesn't start? well its your distubter those sensors CKP/TDC/CYP are built in the distubter, the plug that is connected to the dizzy you can get a ohmmeter and check the resistance in each terminal there should be between 350-700 ohms. so its probably that the dizzy is bad and you need to replace it.
Old May 5, 2006 | 04:51 PM
lshatch1.8's Avatar
Default Re: (honda_civic1)
no the car starts and runs but check engine light is on and after a while it dies there is a plug but no were to plug it into( thats what im trying to find out) ive looked but cant find it its just a single grey-white wire going to the plug were do i hook it up to anyonw?
Old May 5, 2006 | 11:04 PM
lshatch1.8's Avatar
Default Re: (lshatch1.8)
anyone???
Old May 6, 2006 | 06:13 AM
SVOboy's Avatar
That sensor is in the distributor. Check the dizzy wiring, if not try a new dizzy/ecu and see if it fixes it. It's usually dizzy but once I got a tdc code 8 with a bad ecu.
Old May 6, 2006 | 10:04 AM
lshatch1.8's Avatar
Default Re: (SVOboy)
yeah only thing i dont get is i have a seprete plug that doesnt go into anything on the cx harness.... and its for the 4 CKP - crank position sensor so im wondering were i could plug it into or if i could just hook up the wire someone plz help me thanks
Old May 6, 2006 | 10:13 AM
well for that ckp wire there should be two wires light blue, and a light blue/yellow is do you see any these wires?? if so you can hool it up to the ecu wires. lmk
Old May 6, 2006 | 10:29 AM
SVOboy's Avatar
The extra plug might not mean anything. I have three extra plugs on my harness that don't do anything,
Old May 6, 2006 | 11:06 AM
lshatch1.8's Avatar
i just need to know were it plugs into or were i can splice it to.. what wire should i hook it up to? something on the distrubiter id think..
Old May 6, 2006 | 12:15 PM
lshatch1.8's Avatar
bump i need help homies
Old May 6, 2006 | 02:28 PM
lshatch1.8's Avatar
Default Re: cx motor into 93 dx throwing code 4 but cant find a plug to plug it up (lshatch1.8)
bump
Old May 6, 2006 | 04:11 PM
SVOboy's Avatar
Get an ecu pinout and a distributor wiring diagram and you're set.
Old May 6, 2006 | 04:17 PM
blueshark's Avatar
Go ot your nearest Honda dealer and ask to look at the ETMs for both the CX and the DX. You'll get your answers there!
Jesse_Boyer
12
Dec 24, 2024 02:21 AM
new_climber
Sep 15, 2009 09:22 PM
Niskyspy
13
Mar 10, 2008 05:54 PM
CRX MASE
12
Sep 25, 2006 07:42 PM
2fast4udude
16
May 4, 2006 09:50 PM
