92-95 3dr hatchback. Rear window question.
Old May 5, 2006 | 04:02 PM
dem0nk1d's Avatar
Default 92-95 3dr hatchback. Rear window question.
Is there any way to remove the rear wiper from the rear window, and make it look cleaner and still beable to latch.
Old May 5, 2006 | 04:10 PM
CarbonEGG's Avatar
Default Re: 92-95 3dr hatchback. Rear window question. (dem0nk1d)
What does the wiper have to do with it latching?
Old May 5, 2006 | 04:12 PM
dennis278's Avatar
I think that you can take apart the casing that holds the wiper motor and remove the motor and drive shaft, then just find yourself a plug that will cover the hole.
Old May 5, 2006 | 04:29 PM
Ross 2.0's Avatar
In a Junkyard near you.
Default Re: (278civ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 278civ &raquo;</TD></TR><TR><TD CLASS="quote">I think that you can take apart the casing that holds the wiper motor and remove the motor and drive shaft, then just find yourself a plug that will cover the hole.</TD></TR></TABLE>
You can get the plug from your dealer mainly since some didn't come with it.
Send me the motor. i need a replacement
Old May 5, 2006 | 05:09 PM
ZipTieGUy's Avatar
yea,,, just unbolt it and put a plug in its plac.e.
Old May 5, 2006 | 05:13 PM
EG6_GUY's Avatar
You'll need the rear assembly from a CX. From the outside it just looks like a plug, but on the inside it has a latch that functions like the one integrated into the wiper motor.
I believe there is also a little handle that gives you something to lift with.
15&25 in the pic, maybe.
Here's the link:
http://www.hondaautomotivepart...LGATE
ep3man
Sep 14, 2008 12:07 PM
EG cody
Jun 18, 2007 11:13 PM
Bignel00
Jan 1, 2007 12:35 PM
BeeResp0nsible
Feb 17, 2003 11:52 PM
redteg1
Aug 29, 2001 03:19 PM
