Problems with intermediate shaft
I have a 99 Gsr Engine with a 96 Gsr transmission for what it matters. I have come across a problem I have never had in the many, many motor swaps I have done. I went to put my intermediate shaft in the other day and it went in the transmission fine, so then I tried to bolt it up and it appeared to be in a bind and the bolt hole were hard to line up. Well I finally got it lined up, bolted it down and checked to make sure it would spin freely. I notice it would only spin about 3/4 of the way freely and then bind up, even in neutral. Then I checked where it goes into the transmission and the metal seal on the intermediate shaft was not flush on about 1/4 of the area where it enters the transmission. Oil was leaking from this seal. Now I know the metal seal is only the cover and there is a rubber seal in the tranny, I am just stumped on this problem. Most intermediate shafts go right in and bolt up with no effort. Could I have a bent intermediate shaft? Or maybe the shaft didn't go into the tranny completely? I am lost. Any help would be appreciated. Thanks in advance.
You wouldn't have any idea of what may be blocking it would you? I mean it goes in, but when you go to rotate the end where it bolts up its like it doesn't want to sit fluch on the back of the block.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slo4door »</TD></TR><TR><TD CLASS="quote">You wouldn't have any idea of what may be blocking it would you? I mean it goes in, but when you go to rotate the end where it bolts up its like it doesn't want to sit fluch on the back of the block.</TD></TR></TABLE>
I'm running into this exact problem on my B16A2 swap. Did you ever figure this out?
Okay, I brought my intermediate shaft back to the shop I got it from and swapped it for another one. Apparantly, there are two different types of intermediate shafts. I'm guessing the one I had is for auto trannies since the flange face that mounts to the block is located slightly off.
Hockey27925
Jul 21, 2005 04:56 PM
