HELP HELP car wont start HELP HELP
Old May 5, 2006 | 02:10 PM
SLO Sol's Avatar
Default HELP HELP car wont start HELP HELP
installed foglights today and ran a compression test on the SI well for some reason she wont start now.. new plugs, wires im thinking it could be flooded but how do i fix that if it is.... any other ideas i did blow a fuse when i was connecting the fog lights but that was the power for them... I NEED HELP
Old May 5, 2006 | 02:33 PM
ZipTieGUy's Avatar
well if it wont start after your fog light install then you fucked something up. check all fuses
Old May 5, 2006 | 03:57 PM
postman's Avatar
Default Re: HELP HELP car wont start HELP HELP (D-money 92si)
did you pull the backup fuse before compression test,
Old May 5, 2006 | 04:01 PM
scrappysofly's Avatar
Default Re: HELP HELP car wont start HELP HELP (postman)
efi usually doesnt flood out especially from a comp test but incase it did check all your fuses and take the plugs out and turn it over for a couple seconds let the gas get out of the clyinders and leave the plugs out for a while to dry out
Old May 6, 2006 | 07:06 AM
SLO Sol's Avatar
Default Re: HELP HELP car wont start HELP HELP (scrappysofly)
we are thinking its the ground for the motor... i checked the fuses everything is good im going to pull a plug and ground it and see if there is a spark when it is turning if not that could be the problem possibly distributor cap?
steveo135
Jan 8, 2008 06:55 PM
filet611
May 27, 2006 08:40 AM
xhimurakenshinx
Apr 2, 2005 06:36 PM
xhimurakenshinx
Mar 29, 2005 08:12 PM
0ptimus prime
Jun 8, 2003 02:51 PM
