H22a swap in an ek
Ppl i am a noob and i am thinking of swaping an h22 int my ek. I need a break down of what i need in pieces. i already know i need and engine and tranny and ecu and harness and motormounts. What else do i need?
You will Need aftermarket axles such as Dss axles. Just tell them what model car you have and what motor swap you are putting in and what mounts you are using and they will ship you the right axles you will need (no stock axles will be the right length). You can get the 200hp axles for about 300 bucks with a limited warranty.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dominicanstylz02 »</TD></TR><TR><TD CLASS="quote">how about the shifter i heard you have to modify it and also shift cables do i need them?</TD></TR></TABLE>
Yes.
Please use the search and the FAQ stickys. Don't forget to check the Hybrid forum. There are hundreds of threads pertaining to this topic. Here are just a few:
https://honda-tech.com/zerothread?id=434668
https://honda-tech.com/zerothread?id=362984
https://honda-tech.com/zerothread?id=650329 <- TONS of good information
Yes.
ballerchild
May 17, 2007 09:39 PM
