anyone ever used one of these? oil drain valve/bolt for oil pan
Old May 5, 2006 | 01:25 PM
RTW DC2R's Avatar
Default anyone ever used one of these? oil drain valve/bolt for oil pan
edit: site wont let me link to pic copy/paste instead https://ssl2.adhost.com/fumoto...2.JPG
http://www.fumotovalve.com/
more detail http://www.villacorte.com/miata/fumoto_drain_valve/
Old May 5, 2006 | 01:39 PM
Erik95LS's Avatar
Default Re: anyone ever used one of these? oil drain valve/bolt for oil pan (clip the apex)
Never heard of it. is it really that hard for some people to just unscrew one bolt?
I didn't notice if it had any way of locking, but I'd be pretty nervous about that popping open after some debris hits it.
Old May 5, 2006 | 01:42 PM
db8sirg's Avatar
Default Re: anyone ever used one of these? oil drain valve/bolt for oil pan (Erik95LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erik95LS &raquo;</TD></TR><TR><TD CLASS="quote">Never heard of it. is it really that hard for some people to just unscrew one bolt?</TD></TR></TABLE>
really. lazy us. anything for a shortcut.
i see maybe one pro for this mod. no more crush washers
Old May 5, 2006 | 01:48 PM
RTW DC2R's Avatar
I think it has a locked position when its all the way closed, you have to pull on it to open it
Its not just unscrewing the bolt. Its about dropping it in the drain pan, or burning yourself on hot oil.
I rarely ever change my crush washer anyway so that doesnt bother me.
only downside I see is that it may not drain all small metal filings that accumulate near the drain due to the smaller opening.
Old May 5, 2006 | 02:48 PM
BMaDOHC's Avatar
Default Re: (clip the apex)
definitely too lazy for me, 17mm is all it takes
Old May 5, 2006 | 03:02 PM
__oversea's Avatar
wow,people are so lazy these days.
Old May 6, 2006 | 10:23 AM
CRX7's Avatar
I bought one for my S2000 so I would be able to change the oil without getting underneath the car. Jacking it up was a huge pain, and getting under it you had 3 feet of nose above you before you got to the engine, it's that far back. With the valve you could just reach down from on top. Kept it when I sold the car, now I just but it on my b16 rex since it was laying around doing nothing.
Old May 6, 2006 | 11:14 AM
RTW DC2R's Avatar
but guys, 17mm wrench works fine. dont be so lazy
/sarcasm
Old May 6, 2006 | 01:54 PM
nholmes's Avatar
If anything, that would be good for quick oil changes at the track.
Old May 6, 2006 | 02:32 PM
B2FiNiTY's Avatar
Default Re: (nholmes)
Lots and Lots of s2000 owners run those valves and I have heard good things about them.
Old May 6, 2006 | 04:48 PM
__oversea's Avatar
only thing good about is, if i over fill the oil. it will be easy to drain some of it.
Old May 6, 2006 | 06:29 PM
88 rex's Avatar
Default Re: anyone ever used one of these? oil drain valve/bolt for oil pan (Most Known Unknown)
On the topic of oil changes and odd that things that may help....
Has anyone tried something like filtromax? http://www.filtromax.com
Looks interesting. I don't see any downsides other than losing $30.
Old May 6, 2006 | 06:42 PM
infulleffect's Avatar
Default Re: anyone ever used one of these? oil drain valve/bolt for oil pan (88 rex)
I have one on my wifes car...it works great. Super easy oil changes that make no mess. Yeah it is lazy, but it makes life a bit easier and I don't have to be on the ground for long at all. They also offer a barbed fitting so you can attach a hose to it for even easier draining
Old May 6, 2006 | 08:01 PM
CRX7's Avatar
Maybe I should get some magnets off the fridge and try those. Ya, this is the same as the magnetic drain plugs you see. Don't know if there's a magnet in the engine, but there's one in the transmission casing.
paawk2000
Jul 16, 2007 07:54 PM
93(Civic)EG6
Nov 3, 2006 02:25 PM
RemerLex11
Mar 28, 2005 08:35 AM
kjohnl
Mar 5, 2005 10:45 PM
teewhy55
13
Dec 13, 2004 11:17 AM
