hate these damn thing
Old May 5, 2006 | 12:42 PM
JJ's civic's Avatar
Default hate these damn thing
jsut started to take the front end off my parts car today so i can swap them into my driver and it's been like an hour now and i'm still trying to get the damn rotor off i hate those damn screws.
Old May 5, 2006 | 12:47 PM
Suck my DX's Avatar
Default Re: hate these damn thing (joeny12985)
stick ur screwdriver in the screw and bang it a few times with a heavy hammer and try it again...usually comes out pretty easy after that...if not i usually end up chiseling em out...
hey do u still got ur chassis harness on ur parts car?
Old May 5, 2006 | 12:48 PM
JG90CRX-Si's Avatar
You need a impact screw driver thingy-ma-bopper, I forget what it's called. You hit the back end with a hammer and the driver turns a 1/4" or so at a time. This works pretty good.
Have you tried WD40 or PB blaster?
If you didn't live a billion miles away I'd let you borrow mine!
Good Luck
JG
Old May 5, 2006 | 03:28 PM
Blue Si #72's Avatar
Default Re: hate these damn thing (JG90CRX-Si)
Or a simple pointed chisel and a hammer will work.
In fact if you look at the screws they are already dimpled where you're supposed to put the point of the chisel.
Old May 5, 2006 | 03:29 PM
JJ's civic's Avatar
i started to drill them out but my drill died so i'm going to have to mess with it tomorrow before work. i start to unbolt everything else what size is the axle nut????
Old May 5, 2006 | 03:33 PM
Targa250R's Avatar
be professional
Working on cars is easy as pie when you have all the right tools. An impact driver is perfect for removing rotor screws.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joeny12985 &raquo;</TD></TR><TR><TD CLASS="quote">what size is the axle nut????</TD></TR></TABLE>
32mm.
Old May 5, 2006 | 03:34 PM
FOMULA91's Avatar
32mm
Old May 5, 2006 | 03:35 PM
JJ's civic's Avatar
Default Re: hate these damn thing (FOMULA91)
thankx.
B_Swapped93
Dec 6, 2013 06:30 PM
Boner_Ben
May 26, 2009 06:53 PM
Charliegrs
Nov 27, 2006 11:11 AM
mrmonk
Jul 20, 2004 12:20 AM
Wet Nudl
Apr 30, 2002 07:17 PM
