Fastbrake upgrade ?s
Old May 5, 2006 | 11:13 AM
broketuner-Sol_Si's Avatar
Default Fastbrake upgrade ?s
After searching I found nothing that would be applicable to me here on HT. I went to http://fastbrakes.com/shop/. They have several different kits available for my EG. However I'm running on 15x6.5 Racing Hart CP035 and noticed that some of the 11" brake packages said they will clear some 15" wheels. I was wondering if I'd be ok with 11" rotors or should I get the 10.2" kit to play it safe. Also are the fastbrake packages good or should I go with wilwood.
Old May 5, 2006 | 11:15 AM
Stoich EG2's Avatar
Default Re: Fastbrake upgrade ?s (broketuner-egb16a)
it's not necessarily the rotors that will prevent you from using 15" rims, but rather the CALIPERS. 11" rotors were standard for ITRs... and they have stock 15" rims. you should be fine.
Old May 5, 2006 | 11:29 AM
the jdmchop's Avatar
Default Re: Fastbrake upgrade ?s (ADVAN EG2)
i bought the kit but havent put it on yet, tryin to sell them but i contacted fastbrakes and he said all i would need is like a 5mm spacer for the fronts if my rims didnt fit. slips dont fit but curcuit 8's do!
if your intrested in them ill sell them cheap!
Old May 5, 2006 | 12:16 PM
Default Re: Fastbrake upgrade ?s (jdmchop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmchop &raquo;</TD></TR><TR><TD CLASS="quote">if your intrested in them ill sell them cheap! </TD></TR></TABLE>
Right now I'm just doing research, on what I can do. If they're still available in a month or two(or whenever I get more $ for parts) I'll take the fronts, I already have rear discs.
Old May 5, 2006 | 12:23 PM
yea if they dont sell in a couple weeks there gonin on for sure
Weel
24
Oct 26, 2011 11:04 AM
wenlyone
Aug 8, 2011 12:37 PM
Weel
Suspension & Brakes
May 26, 2009 11:01 AM
fujii13
Apr 7, 2005 08:44 AM
. o 69 o .
Oct 29, 2004 02:56 AM
