Ticking sound from exhaust (Not sure about motor)
Old May 5, 2006 | 08:26 AM
Corporation's Avatar
Economic Upturn, WUT
From: Alittle Placed Called None of Your Damn Business.
Default Ticking sound from exhaust (Not sure about motor)
Sometimes when I start the car I get a ticking noise that is quite disturbing. It will tick when I accelerate. But sometimes when I start the car it sounds perfecly normal. The oil is fine in my car (it does leak but I make sure it stays full.) Any other possibilties?
Old May 5, 2006 | 12:11 PM
cm zak's Avatar
you said in ur topic it comes from the exhaust, how do you know this? have you started it and gotten out and listened to where its coming from while its running and making the sound?
Old May 5, 2006 | 01:01 PM
MajorPayne's Avatar
an exhaust leak where the header meets the head will usually make that sound
Old May 5, 2006 | 02:15 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Ticking sound from exhaust (Almightiness)
When is the last time that you adjusted your valves?
If the exhaust is leaking, you can easily test this. Start the car and then have a friend cover the tailpipe with his or her shoe. The leak will quickly become apparent.
Old May 5, 2006 | 11:30 PM
Default Re: Ticking sound from exhaust (Dogginator)
How much do valve adjustments usually cost?
Old May 6, 2006 | 03:43 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Almightiness &raquo;</TD></TR><TR><TD CLASS="quote">How much do valve adjustments usually cost?</TD></TR></TABLE>
I'm not sure. You just want a $13 valve adjustment tool and need a set of feeler gauges. It takes about 30 minutes to complete. it is difficult to have a shop do this because the car needs to sit until the engine is cold.
Here is a how to link:
http://www.c-speedracing.com/h...t.php
Here is a link for the tool:
http://www.amazon.com/gp/produ...28013
Which engine do you have?
Old May 6, 2006 | 10:07 AM
LS motor (stock). And I was also wondering, I had a bad leak out of my oil pump awhile ago and we got that fixed, but now I am still losing a bit of oil on long trips, but I cannot see a leak. Anyone have any guesses?
giovannie23
Nov 21, 2014 11:41 AM
Rok_Stok
11
Oct 6, 2010 02:05 PM
fatpride111
Nov 19, 2008 07:56 PM
EKautox
Aug 18, 2005 09:16 AM
IntegraLs94Cam
Aug 20, 2004 02:00 PM
