00 ex electrical prob.
Old May 5, 2006 | 08:06 AM
mycrx7's Avatar
Default 00 ex electrical prob.
this is about my friends car, 00 civic ex with a gsr swap, car has ran for the past 5 months perfectly fine so its nothing that happened in the swap, im thinking maybe the pgmfi relay "main" but in the fuse box under the hood, the fuse labled FI E/M keeps blowing, what is this fuse for and where can i look to, to fix the problem, the fuel pumps not coming on and im not sure if the ecu is, but this is the fuse thats blowing so i know its something in that circut.
Old May 5, 2006 | 02:11 PM
mycrx7's Avatar
Default Re: 00 ex electrical prob. (mycrx7)
bump for some help!
Old May 5, 2006 | 02:36 PM
hatchi's Avatar
try taking off the ground on the battery first then put in the fuse then put the ground back on
Old May 5, 2006 | 02:47 PM
mycrx7's Avatar
Default Re: 00 ex electrical prob. (hatchi)
it wont blow the fuse til you turn the key to the acc part right b4 the starter engages.
Old May 9, 2006 | 08:29 AM
mycrx7's Avatar
anyone with any help? though this place was boominb with info
Old Jun 27, 2006 | 01:00 PM
jaysteven's Avatar
find someone competent
Old Jun 27, 2006 | 01:14 PM
fmrprojects's Avatar
Default Re: 00 ex electrical prob. (jaysteven)
you have a short somewhere in that circuit. get a diagram and follow all the grounds that is in that circuit and see if it is pinched
Karben
Jun 29, 2014 05:43 PM
Joecivic94
Dec 19, 2012 02:42 PM
97_hatch
May 19, 2008 10:08 PM
SLOW4drINTEG
Nov 13, 2003 08:19 PM
