Crank pulley and bearing replacement.
Alright guys I had an issue a while back where the Key in the crank pulley key was missing for a while. The pulley was torqued down to spec but the pulley still slipped. It ran like this for about 4000 miles. Now I started to notice a really light sorta knock coming from my block and I suspect the bearings to be the problem (people have also told me that the nose is because I am running eagle rods with wiesco pistons that are now full floating wrist-pin instead of pressed oem). Anyways I want to see if I can get rid of is. My question is can I just get new bearings and replace them or do I have to get the crank polished. I pulled the bottom end apart and the rod bearings were fine and there was no scaring at all on the crank itself. Thanks for all your help!!!
mattcivic
Dec 25, 2004 11:13 AM
PHAT R 390
Aug 15, 2001 08:40 PM
