Removed tar, car won't start!!!
Old May 5, 2006 | 05:54 AM
KimChiKid's Avatar
Default Removed tar, car won't start!!!
Hey guys, I have a 1999 Civic Hatchback and I just finished getting rid of all the tar out of the vehicle front to back.
I jumped into the car this morning and now it doesn't start, I think its locked up for sure >.<
I used the dry ice method.
WTF!
Please help me!!!!!!!!!!!
Old May 5, 2006 | 06:17 AM
KimChiKid's Avatar
Default Re: Removed tar, car won't start!!! (KimChiKid)
bump
Old May 5, 2006 | 06:21 AM
existanzcivicb20's Avatar
did you remove any ground wires that u forgot to put back
Old May 5, 2006 | 06:30 AM
KimChiKid's Avatar
I didn't remove shiet I just put the dry ice where all the tar was and just scraped it off....
CRY!!!!!!!!!!!!!!!
Old May 5, 2006 | 06:39 AM
92civichatch1's Avatar
well give us more symtoms than it just doesnt start. does it turn over. does it not do anything when u turn the key. were u listening to music when u did all this cause u probably depleted the battery get a jumper pack and see what happens.
Old May 5, 2006 | 06:40 AM
Mwsol's Avatar
Do you have voltage? Maybe you left the door open too long... Or weak battery.
Old May 5, 2006 | 06:45 AM
KimChiKid's Avatar
Default Re: Removed tar, car won't start!!! (Mwsol)
Sorry, it does crank but other than that it doesn't want to engage.
All the lights and radio and stuff work,
Old May 5, 2006 | 06:51 AM
KimChiKid's Avatar
Jumper Pack didn't work.
Old May 5, 2006 | 06:52 AM
KimChiKid's Avatar
Do you think it has something to do with the rear tar removal?
The fuel tank + dry ice?
What does that do?
Old May 5, 2006 | 07:01 AM
RockLee`'s Avatar
i dunno, someone help this guy out!
Old May 5, 2006 | 07:04 AM
KimChiKid's Avatar
Default Re: Removed tar, car won't start!!! (RockLee`)
I hope I didn't start some chemical reaction....
Old May 5, 2006 | 07:06 AM
CTRwannaB's Avatar
did u pull any fuses before working on the car?
when starting can u smell gas...as in is the car getting gas?
check main things first
gas/spark
Old May 5, 2006 | 07:12 AM
Firstoost's Avatar
First of all dry ice is C02...and c02 is gas..what does gas do? it rises....nothing from the dry ice f ucked up your tank....check your fuel, spark and compression...check to make sure your crank is moving/cam gear is working along with your cam, to work the dizzy
KimChiKid's Avatar
Default Re: Removed tar, car won't start!!! (CTRwannaB)
I didn't do anything to the car period except use dry ice and remove the tar from the entire vehicle.
I promise that is all I did.
Let me try to jump it with another car instead of the battery pack!
Old May 5, 2006 | 07:18 AM
the jdmchop's Avatar
well aboviously you had to remove the carpet to remove the tar!
did you mess up any grounds?
does the fuel pump turn on?
there the ground for the pump near the drivers seat and mabye it got fucked?
Old May 5, 2006 | 07:20 AM
Firstoost's Avatar
Default Re: Removed tar, car won't start!!! (jdmchop)
is it manual? if so you should try to push start it lol
Old May 5, 2006 | 07:24 AM
KimChiKid's Avatar
Ok, let me check.
Old May 5, 2006 | 07:25 AM
miahmouse's Avatar
Default Re: Removed tar, car won't start!!! (Firstoost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmchop &raquo;</TD></TR><TR><TD CLASS="quote">well aboviously you had to remove the carpet to remove the tar!
there the ground for the pump near the drivers seat and mabye it got fucked?</TD></TR></TABLE>
fuel pump or ground...
Old May 5, 2006 | 07:28 AM
KimChiKid's Avatar
No, everything is intact. Obviously the seat belt wire isn't plugged and there is the tube for the rear wiper fluid to pass. Other than that there is nothing.
Maybe the dry ice touched the ecu?
The frustration....
Old May 5, 2006 | 07:40 AM
is the pump turning on?
Old May 5, 2006 | 07:46 AM
Firstoost's Avatar
come on man you need to check your fuel spark and compression
Old May 5, 2006 | 07:49 AM
KimChiKid's Avatar
I guess I am just overwhelmed at the fact that it started yesterday and now all of a sudden it just doesn't start I mean wtf....
Anyways ok Fuel Pump is fine, I am getting spark, how do I check compression?
Old May 5, 2006 | 07:52 AM
compression tester lol
Old May 5, 2006 | 07:53 AM
KimChiKid's Avatar
lol I don't have one of those....
&gt;.&lt;
Firstoost's Avatar
with a compression tester...take out your plugs, put the compression tester in, and have someone crank the engine over until you get a solid reading...but make sure to take out your ecu fuse or you'll be squirting fuel in your eye.
