What is the next step?
Old May 5, 2006 | 05:20 AM
pearlwhite01's Avatar
Default What is the next step?
i have a 2001 prelude se. I have a catback and a ram air intake....i'm looking to continue upgrading however i dont have that much cash....i was wondering what would be the best investment with about $1,500-$2,500 dollars to spend. Im also going to be getting new tires and rims so those are covered.
Old May 5, 2006 | 05:24 AM
94preludeguy's Avatar
Default Re: What is the next step? (pearlwhite01)
Header
Short Shifter
Lowered
Struts
Cam
Then boost it..
Old May 5, 2006 | 06:04 AM
The Weather Man's Avatar
Default Re: What is the next step? (94preludeguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94preludeguy &raquo;</TD></TR><TR><TD CLASS="quote">Header
Short Shifter
Lowered
Struts
Cam
Then boost it.. </TD></TR></TABLE>
Uh....this is why the prelude section is almost junk. Why give him a junk answer?
Why the hell would he buy a header, then try to boost? Is that not a waste of money?
Here's a suggestion:
Do a really nice suspension setup. Then sit down and think about if you wanna boost or go n/a. Don't waste the money on anything right now but the suspension. Because with that little money, you won't be able to finish your setup. You'll be stuck half way.
Old May 5, 2006 | 06:16 AM
JTPerformance's Avatar
Cams
Header
Hondata
Tune
LSD
Clutch
Modified by JTPerformance at 10:30 AM 5/5/2006
Old May 5, 2006 | 07:33 AM
Default Re: What is the next step? (The Weather Man)
i appreciate you taking the time to reply to my question....what do you think is a "good suspension set-up" please keep in mind that i live where ground clearance and winter driving can sometimes (rarely) play a factor....
sway bar? strut bar? coil overs? i have very little info...i've been trying to look this stuff up on the internet but have had very little success hopefully there is some insight with individuals, like yourself, with experience that know which products will yeild the best results...thanks in advance!
Old May 5, 2006 | 07:50 AM
prelude1897's Avatar
I would go with suspension next
Old May 5, 2006 | 08:32 AM
classified's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pearlwhite01 &raquo;</TD></TR><TR><TD CLASS="quote">i appreciate you taking the time to reply to my question....what do you think is a "good suspension set-up" please keep in mind that i live where ground clearance and winter driving can sometimes (rarely) play a factor....
sway bar? strut bar? coil overs? i have very little info...i've been trying to look this stuff up on the internet but have had very little success hopefully there is some insight with individuals, like yourself, with experience that know which products will yeild the best results...thanks in advance! </TD></TR></TABLE>
I'm running a Tokico suspension kit. It includes Tokico 5 way adjustable illumina shocks and Tokico sport springs. The drop is about 1.25-1.5 inches. The ride is near stock when the shocks are at the softest setting. You don't require a camber kit with this drop either. Here's a pic, it still gives excellent clearance even if you have an oem kit.
Old May 5, 2006 | 10:14 AM
Default Re: What is the next step? (spirctsae)
Thanks spirctsae your car looks awesome!.... i have pretty much the exact same car except white and the drop looks just right i find the the space between the rear tires and body is way too high....yours looks great!
Just out of curiosity how much did u end up paying in the end? did you get a mechanic to do it or did u do it yourself?
Thanks!
Old May 5, 2006 | 10:31 AM
classified's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pearlwhite01 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks spirctsae your car looks awesome!.... i have pretty much the exact same car except white and the drop looks just right i find the the space between the rear tires and body is way too high....yours looks great!
Thanks!
I actually managed to find the Tokico suspension kit on ebay from a reputable seller and got a killer deal. I would've paid around 1000-1200 cnd locally but ended up paying about 700-800 cnd instead. Just make sure if you do order the same kit that you get the Tokico Illumina kit and not the Tokico HP blues kit. The Illuminas are actual performance shocks while the HP's aren't much sportier than stock. I installed them all myself on a weekend.
Old May 5, 2006 | 11:15 AM
thats fresh's Avatar
suspension seems like a good direction
Old May 5, 2006 | 11:56 AM
oranginal's Avatar
TEIN is growing in popularity, you might want to check them out b4 making a final decision
also KYB AGX make great struts/shocks from what i've heard.
i am going to be getting a new suspension soon and i am leaning toward KYB AGX with TEIN springs
Old May 9, 2006 | 08:44 PM
flipwhip's Avatar
Default Re: What is the next step? (oranginal)
I got the tociko blues and I think there a hell of a lot better than stock, plus I like the 1.5'' drop. Actually I think my stock shocks were pretty much gone (94 lude) so Im not really sure Im just very happy with the blues. Handle great.
Old May 9, 2006 | 08:56 PM
soundbomber's Avatar
Default Re: What is the next step? (flipwhip)
JUN CAMS and JUN VALVETRAIN
found here: https://honda-tech.com/zerothread?id=1480771
Old May 10, 2006 | 05:06 AM
Well I'm sorry that my answear to his question was "junk". Obviously if he plans on boosting then he would disregard buying a header...
Old May 10, 2006 | 05:31 AM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Weather Man &raquo;</TD></TR><TR><TD CLASS="quote">Uh....this is why the prelude section is almost junk. Why give him a junk answer?
Do a really nice suspension setup. Then sit down and think about if you wanna boost or go n/a. Don't waste the money on anything right now but the suspension. Because with that little money, you won't be able to finish your setup. You'll be stuck half way. </TD></TR></TABLE>
good advice
Old May 10, 2006 | 06:42 AM
darkspector's Avatar
the form/function coil-overs are supposed to be a really good setup. Good spring rates, dampening adjustable, and adjustable shock body so you odn't have to mess with spring perch. D2 has about the same setup. For either I think the price is about ~900 shipped. I've good things about both coilovers. And with what's left over you can get poly bushings and probably a sway bar.
Barry White Wagon
Sep 2, 2008 01:57 PM
bjcroce
Sep 21, 2005 04:44 PM
BottleFedCobra
Oct 26, 2004 03:11 PM
yisoulja
Aug 12, 2003 10:26 PM
