ecu prob
Okay well i thought maybe i had a bad ecu cuz the light wud come on and stay on. well i swapped ecus and while doing that i noticed awire from the piggy back came loose. well now im throwing a code 5 and 6 when i put it in a slot. some times i only throw 5 n sometimes i throw 6 too. well 5 is map sensor and 6 is coolent temp. well could these prevent my car from starting? And does anyone know what the map sensor should read with a multimeter? i found the post a couple days ago but now i cant find it. thnks.
Did you really need to make 2 posts about this?
Anyway...go get a pin out of your ecu and find where the wire goes that has fallen out. The simply put it back in. Then if that doesnt fix the cel's yu can go on to try other things. This is called trouble shooting. Go get a Helms manual...itll help alot.
BTW-you coulda posted this in the other thread
sorry bout that guys i thought that i should make another one. but it cranks over but doesnt start. it almost fires up but it doesnt. im gonna go check the timiing make sure i didnt mess up the ignition timing
bmoua
Apr 15, 2007 12:24 AM
debogsr
Sep 30, 2005 10:33 AM
