My new turbo, can someone identify this?
Old Apr 9, 2002 | 11:11 PM
Ri5e's Avatar
Default My new turbo, can someone identify this?
I bought this off of Jetli6969. Gonna put it on in a few days when my car gets back from Radley Acura. Damn thieves broke my ignition...
Its a T3/T4 Garrett (I think). No Garrett stamp on it anywhere. Exhaust has .48 stamped into it (on the inside).
Not sure about anything else! Looks like a very quick spooling turbo.
Old Apr 10, 2002 | 12:03 AM
DLB1994's Avatar
Default Re: My new turbo, can someone identify this? (BG Boost)
get a pic of the blades
Old Apr 10, 2002 | 05:23 AM
92HB_HB's Avatar
that looks like a t3t4b.. I have the same exact compressor housing.. so i'm pretty sure its the same ..
Old Apr 10, 2002 | 05:50 AM
Dee's Avatar
Dee
Default Re: My new turbo, can someone identify this? (92HB_HB)
6 blade/6 splitter compressor blade = T04E
7 blade/7 splitter compressor blade = T04B
Check the major and minor diameters of the compressor blade
[Modified by Dee, 7:14 PM 4/10/2002]
Old Apr 10, 2002 | 06:14 AM
int3gra's Avatar
Default Re: My new turbo, can someone identify this? (Dee)
inlinepro!
that came with it?
Old Apr 10, 2002 | 07:41 AM
Ri5e's Avatar
Default Re: My new turbo, can someone identify this? (int3gra)
So your saying if its double 6 its T04b and if its double 7 blades its t04e?
The Inline pro manifold did not come with it. I bought that seperately. And polished that bizotch by hand.
[Modified by BG Boost, 4:42 PM 4/10/2002]
Old Apr 10, 2002 | 07:49 AM
rtype11's Avatar
if you polished your manifold with a wire wheel and not aluminum oxide sand paper, your manifold will rust! Take it to a metal treater and have them do a 300 series passivation in nitric acid at 140 degrees for half an hour.
Old Apr 10, 2002 | 08:12 AM
DIRep972's Avatar
Smarter than you
if thats not a T3/T04B i dont know what is..
Old Apr 10, 2002 | 11:22 AM
Giuseppe's Avatar
Default Re: My new turbo, can someone identify this? (rtype11)
this is the first inlinepro manifold ive seen, and
that thing has a "stainless steel" stamp on it..
rtype11 are u saying he polished the protective coat off.??
Old Apr 10, 2002 | 02:01 PM
The Mick's Avatar
That isn't correct. The double 6 wheel would be a T04E.
Old Apr 10, 2002 | 03:15 PM
Dee's Avatar
Dee
Default Re: My new turbo, can someone identify this? (The Mick)
oops.. sorry I wrote T04E twice! T04B has a 7/7 setup!
Old Apr 10, 2002 | 04:38 PM
jetli6969's Avatar
New User
dood you got ripped off, thats a t25 man!!
Old Apr 10, 2002 | 04:50 PM
Giuseppe's Avatar
Default Re: My new turbo, can someone identify this? (jetli6969)
arent u the seller.????
Old Apr 10, 2002 | 09:09 PM
Ri5e's Avatar
Default Re: My new turbo, can someone identify this? (Giuseppe)
lol jet li 6969, u bastard!!!! j/k.
Old Apr 11, 2002 | 05:07 PM
Ri5e's Avatar
It has 6 double blades. But looks a LOT smaller then the one I had before which was a t3/t4e...
Anyone else?
Old Apr 11, 2002 | 06:25 PM
Dee's Avatar
Dee
the only way to know for sure is to measure the major and minor diameters of the compressor blade!
Old Apr 12, 2002 | 05:37 AM
Ri5e's Avatar
How do you measure that? Also which one is major and which one is minor. thanks.
Old Apr 12, 2002 | 05:46 AM
Dee's Avatar
Dee
major = largest diameter (compressor exducer)
minor = smallest diameter (compressor inducer)
Remove the compressor housing (six 12mm bolts and and three clamp sets), pull the housing off and then measure the two diameters of the blade with a micrometer (or caliper and ruler).
HTH...
theEGkid
Sep 22, 2005 10:44 AM
NotPhilTran
May 2, 2005 06:00 PM
TURBO DC2
Mar 28, 2005 07:25 PM
AVATAR
Jan 3, 2003 11:43 PM
Ri5e
Apr 25, 2002 11:22 PM
