Which CAMS to run on a Built GSR?!
As some of you know, I've been working on my rebuild/new build for quite a while now. Here's the set up:
-p&p gsr head
-supertech std valves
-supertech valve springs
-jg retainers
-skunk2 cam gears
-skunk2 IM w/ ITR TB
-RC310 injectors
-Cometic Headgasket
-Balanced and Blue printed GSR Block
-arp rod bolts/head studs
-CTR .25 oversized pistons
-ITR crank pulley
-Balanced 12.5 lb ACT flywheel
-190lph walboro fuel pump
will be tuning with crome
Question is, I currently have a set of Blox B's sitting here, but some have said I should run more agressive cams? I'm worrying about reliabilty since this is going into my daily driver with occasional track; auto-x & drag. Also, passing emissions would be out of the question I assume if I go with anything bigger? Also, which spark plugs would be good/safe? the ngk-bkre6 or 7-11?
Any suggestions, recommendations, etc. would be greatly appreciated. THANKS H-T!
-p&p gsr head
-jg retainers
-skunk2 cam gears
-RC310 injectors
-Cometic Headgasket
-ITR crank pulley
so you want a reliable daily driver, that you will drag and roadrace..lol.
roadrace + max reliability = bc3+
drag + max reliability = blox b/skunk2 stg 2 (same shizzle of course)
drag + autorace = less reliability = Toda C
just my humble opinion.
thanks for the input guys..... This motor/car will be more of a daily driver than anything..the racing; drag/auto x will only be once every few months or whatever. So should I stick w/ the blox b's then?
If you already have the B's I would use those, you don't need a more aggresive cam. If you wanted to sell them and buy something else, the RM M22x's would work awesome for you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVOL »</TD></TR><TR><TD CLASS="quote">bc3+ will give you more everyday midrange.
wow you have CTR pistons in a gsr longblock.
hmm..</TD></TR></TABLE>
yeah, we'll see how these ctr oversized pistons work in this gsr block. Yeah, I think I'll just stick with what I have. Thanks again people!
Any more suggestions would be greatly appreciated and accepted
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iTz A HONDA ThAnG »</TD></TR><TR><TD CLASS="quote">TODA CAMS
umm...ok, which ones and why? spec a, b, c?
</TD></TR></TABLE>umm...ok, which ones and why? spec a, b, c?
iH8RICERZ
31
Sep 3, 2009 09:40 PM
Fuzion
Sep 9, 2003 04:39 PM
