How to remove the tail light off 98-02 coupe v6
Old May 4, 2006 | 10:31 PM
lostcause's Avatar
Default How to remove the tail light off 98-02 coupe v6 help please!!
I'm trying to figure out how to remove the tail lights off the accord and couldn't seem to do it. I'm trying to replace my friends tail light bcuz he was hit. Can someone tell me how to do this, because I can't seem to figure it out. his car is a 2001 accord coupe v6.
Modified by lostcause at 12:06 AM 5/5/2006
Old May 4, 2006 | 11:26 PM
YeuEmMaiMai's Avatar
Default Re: How to remove the tail light off 98-02 coupe v6 help please!! (lostcause)
remove them by removing the covers and unbolting all of the screws after you un-plug the wiring harness
Old May 5, 2006 | 04:54 AM
lostcause's Avatar
wow that was so obvious, im trying to figure out which bolts
Old May 5, 2006 | 05:17 AM
Default Re: (lostcause)
WOW how about all of them that are holding the fixture to the car?
I think you should leave the repairs to more qualified people if you cannot figure out how to remove 3 or so bolts from the housing (one on each corner).
Old May 5, 2006 | 06:12 AM
S CARTER's Avatar
If its the tail lamp on the outside...
Taillights
Open the trunk lid and pull back the trunk side trim.
Disconnect the 6P connector (A) from the taillight (B).
Remove the four mounting nuts (C), then pull out the taillight (B).
NOTE:
Inspect the gasket: replace it if it is distorted or stays compressed.
After installing the taillights, run water over them to make sure they do not leak.
TURN SIGNAL/TAILLIGHT BULB:
27/7 W
BRAKE/TAILLIGHT BULB:
27/7 W
RickR
Mar 11, 2010 12:49 PM
rob[CB7]
Aug 30, 2008 12:23 AM
jaM3s Bond
May 6, 2003 09:04 AM
prod19y
Feb 5, 2003 10:23 PM
silveraccord01
Jan 2, 2003 03:07 PM
