anyone know the proper clutch pedal engagement point and free play on 97 prelude?
i'm about to install an Exedy Stage 2 clutch kit and i was wondering what the proper specification for the clutch pedal engagement and free play etc. on the 5th gen honda prelude? i did an automatic to manual swap on my 97 honda prelude a year a go, but never got the exact specification of the clutch pedal and i just adjust my clutch the way i want the engagement point to be(higher or lower). is it ok if you don't follow the OEM clutch pedal engagement point?
the reason im changing my clutch out to a exedy stage 2 because im going turbo and i don't think my exedy stage 1 can handle it. also im taking out my engine so may as well do a new clutch and flywheel job.
You will adjust at the pedal. Free play should be 3/4 inch from top to release bearing load.
since im running aftermarket clutch, and master cylinder, doesn't OEM Spec won't matter anymore?
