CTR semi build
Old May 4, 2006 | 08:07 PM
SOILNATURE's Avatar
Default CTR semi build
I have a ctr motor and It has a ITR crank, with gsr rods , and over size ctr pistons.
My question is, will I have to mill the pistons so it wont hit the head?
Old May 4, 2006 | 08:23 PM
allmotormatt's Avatar
Default Re: CTR semi build (SOILNATURE)
nope you dont the block is the same as the gsr the head is like a b18 type r but the valves sit at a slightly different angle i think so either way i dont think you have to mill them i had those pistons in a gsr block with a gsr head and bc4 cams and never had a problem
Old May 4, 2006 | 08:29 PM
SOILNATURE's Avatar
thanks for the info.
Old May 4, 2006 | 08:40 PM
Default Re: (SOILNATURE)
no prob man
Old May 4, 2006 | 08:47 PM
B18C1_POWER's Avatar
Default Re: CTR semi build (allmotormatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotormatt &raquo;</TD></TR><TR><TD CLASS="quote">nope you dont the block is the same as the gsr the head is like a b18 type r but the valves sit at a slightly different angle i think so either way i dont think you have to mill them i had those pistons in a gsr block with a gsr head and bc4 cams and never had a problem</TD></TR></TABLE>
How much whp in your setup??
Old May 4, 2006 | 09:04 PM
Default Re: CTR semi build (B18C1_POWER)
i made 211whp tuned by jeff evans at evans tuning my graph is still on his site
Old May 4, 2006 | 09:14 PM
also go to search and type in mild build 211whp and see my thread
Old May 4, 2006 | 09:32 PM
RaceCarRyne's Avatar
Old May 5, 2006 | 11:40 AM
SOILNATURE's Avatar
Is ther port different on a ctr head
Old May 5, 2006 | 03:57 PM
i dont think there is a differance between the civic type r head and the integra type r head port wise but if i can find the link that explains everything about the civic type r ill be sure to post it
Old May 5, 2006 | 09:26 PM
SOILNATURE's Avatar
Cool,
enokcrx
23
Jul 9, 2013 07:04 AM
shatchi
13
Apr 7, 2006 06:27 PM
kidd_drastic
17
Nov 14, 2005 09:56 AM
G U E C O
29
Sep 11, 2003 08:05 AM
lowkeyciv
Apr 25, 2003 03:57 PM
