weak idle
Old May 4, 2006 | 07:03 PM
ex94vtec's Avatar
Default weak idle
my idle seems very weak after the car has been started and is at normal operating temperatures unless i have the air on full blast it will idle around 200rpm maybe even a little lower. with the air on full it will idle usually around 500rpm...any1 know what could be causing such a weak idle. I think it should be atleast around 800rpm...
Old May 4, 2006 | 07:41 PM
movingIIshadow's Avatar
Default Re: weak idle (ex94vtec)
Bump.... same problem for a long long time
Old May 4, 2006 | 09:42 PM
ex94vtec's Avatar
any1?
Old May 4, 2006 | 09:48 PM
g0tsilkk's Avatar
Default Re: (ex94vtec)
i just raised the idle on the trottle body. it works and my car doesnt idle low no more. you might want to try that. when raising it, you turn it counterclockwise with a screwdriver
Old May 4, 2006 | 10:15 PM
ex94vtec's Avatar
Default Re: (g0tsilkk)
what did u adjust exactly...the throttle itself?
Old May 5, 2006 | 12:15 AM
Elwuudz's Avatar
timing...
i arched my belt... and slipped a couple teeth
this slip threw off my timing and made it impossible to acclerate
Old May 5, 2006 | 12:17 AM
Elwuudz's Avatar
that is not adjusting the idle... or tuning the idle..
that is merely tightening the line to supply more fuel to your engine and resulting a higher idle... hovering idle
timing will correct this issue
Old May 5, 2006 | 05:01 AM
killerformula's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ex94vtec &raquo;</TD></TR><TR><TD CLASS="quote">my idle seems very weak after the car has been started and is at normal operating temperatures unless i have the air on full blast it will idle around 200rpm maybe even a little lower. with the air on full it will idle usually around 500rpm...any1 know what could be causing such a weak idle. I think it should be atleast around 800rpm...</TD></TR></TABLE>
I'm with you man, I've had the same problem for a while, although its hit and miss. Given that, I dont think its timing (at least in my case). Turning up the idle seems like a bad idea too, just putting a band-aid on the problem really. I've seen a bunch of posts on this issue and haven't ever seen a solid answer even though it seems so common! I figured for a while that it might be the IACV, but another guy with the same problem said he tried 3 different valves with no good results...
Let us know if you find anything-
K
Old May 5, 2006 | 10:15 AM
ex94vtec's Avatar
Default Re: weak idle (killerformula)
yea i had the same problemw ith my last coupe... i havent found any good info myself so far tho
i will be putting ona new timing belt when i take my head off to put in a new gasket and arp headstuds...will a new timing belt fix this issue?
Old May 5, 2006 | 10:27 AM
honda_civic1's Avatar
if the timing was off you would have problems with other things,when it comes to timing to plays a huge role if its off a tooth well your going to find it hard to start etc. On the trottle body there is a Flat head Screw the is located on the top this adjust your idle depending on which way you go you can make it idle high or low so just turn it untill your idleing normal.
Old May 5, 2006 | 10:38 AM
ex94vtec's Avatar
Default Re: (honda_civic1)
well i know my timing isnt off... i will just try adjusting that screw...why would my idle be shitty in teh first place tho? if adjusting the screw fixes it then cool...but why would it be so low in teh first place?
Old May 5, 2006 | 01:46 PM
blackoliveEk's Avatar
Check your throttle position sensor on the back of the throttle body, make sure its not cracked or wires are faulty, it can cause idle problems
Bump
Old May 5, 2006 | 02:57 PM
ex94vtec's Avatar
well i tried adjusting the idle screw and that did nothing...could it possibly be a vacuum leak somewhere causing it? I will check the throttle postion sensor next...
Old May 5, 2006 | 03:32 PM
yes if there is a vaccum leak it would do that too, and check your idle controller sensors which are located near the trottle bodie/intake manifold.
Old May 6, 2006 | 02:07 AM
RTI's Avatar
RTI
Default Re: weak idle (Elwuudz)
Are you reading rpm's from the instrument cluster tach? Those are hardly accurate, and don't offer any resolution at low rpm. I'm not saying you don't have a low idle, but I'm not sure if a car will even run at 200rpm. Sometimes the idle adjustment screw doesn't work because it is seldom adjusted and crap builds up in that area of the throttle body over time. Is the car automatic? More than likely the low idle is somehow related to the iacv.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elwuudz &raquo;</TD></TR><TR><TD CLASS="quote">timing...
this slip threw off my timing and made it impossible to acclerate </TD></TR></TABLE>
Are you saying adjust his idle with timing? by mentioning belt and teeth I assume you mean valve timing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elwuudz &raquo;</TD></TR><TR><TD CLASS="quote">that is not adjusting the idle... or tuning the idle..
timing will correct this issue </TD></TR></TABLE>
Are you implying that jumping a tooth or two on the timing belt is a better way to adjust idle than the idle adjustment screw?
axis11
May 16, 2013 08:16 PM
FloridaCivic
18
Feb 24, 2007 12:23 PM
Civic Racer X 7
Jul 23, 2003 07:19 AM
Spade
Jul 1, 2002 10:49 AM
