ONLY half my cluster lights up ??? tach not working.
Old May 4, 2006 | 06:51 PM
h22HatchEG's Avatar
Default ONLY half my cluster lights up ??? tach not working.
Ok went to attempt to mess with my car more and when i got in to start it only 2 of my lights came on the battery and SRS. my CEL and all the others that come on when in the Oh position arent on and while trying to start it it beeps at me to close my door still.
Also when trying to start it my battery light flickers but its got good juice.
Old May 4, 2006 | 07:24 PM
-DesTiNy-'s Avatar
I'm a Jackass
i got same problem with my bros CRX!
bump for good question
Old May 4, 2006 | 08:22 PM
Carbonyl's Avatar
Default Re: (-DesTiNy-)
try the meter fuse under the dash, possibly a blown fuse as an easy explanation. check the other fuses to see if you blew anything else
Old May 4, 2006 | 09:32 PM
h22HatchEG's Avatar
Yea ill check. Figured there was smoethign else. Thought if some lights went they would all go with one fuse.
Old May 4, 2006 | 11:32 PM
honda_civic1's Avatar
why don't you just take out the cluster and check if any lights bulbs are out, if so replace them, check fuses, and you might have a short some where check wires.
Old May 5, 2006 | 05:27 AM
h22HatchEG's Avatar
I checked some wires but dont really know where a short would be all of a suddon. Woulndt be bulbs because my tach would still work i would think.
Old May 5, 2006 | 08:21 AM
no what i'm saying is on the back of the gauge cluster there are little bulbs some of the bulbs might be bad thats why when you turn your lights on just some of the cluster lights up.
Old May 6, 2006 | 03:54 PM
h22HatchEG's Avatar
still got the problem, i tried changing 2 relays under my hood. are there any other ones? also all my fuses are good.
Old May 6, 2006 | 04:49 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: ONLY half my cluster lights up ??? tach not working. (h22HatchEG)
h22HatchEG
It's a blown fuse located at the under-dash fuse box. If I'm not mistaken it's either a 15A or a 20A. It happened to me before.
cleanda6
Oct 29, 2011 09:08 PM
frankfezzie
35
Oct 25, 2005 09:46 PM
POLLO
May 15, 2004 12:20 AM
1sikcoupe
10
May 7, 2004 03:23 PM
mrbsponge
Dec 31, 2003 03:31 PM
