Suspension & Brakes Theory, alignment, spring rates....
LCA/Shock Bolt Size?
Old May 4, 2006 | 06:17 PM
CivicBlack's Avatar
Default LCA/Shock Bolt Size?
Does anyone know the bolt length of the bolt that goes through the rear shock and lower control arm? Helms says 10x1.25 but it doesn't tell the length. TIA.
Old May 4, 2006 | 08:13 PM
TealEG!'s Avatar
Default Re: LCA/Shock Bolt Size? (CivicBlack)
i think it is about 80mm but i am not positive. i was going to get something from home depot when mine broke but ended up getting a new bolt and put my own nut on it.
Old May 4, 2006 | 10:19 PM
CivicBlack's Avatar
Default Re: LCA/Shock Bolt Size? (TealEG!)
aight thanks
Old Feb 23, 2010 | 01:32 PM
dandaman15's Avatar
Community Builder
Reviving old thread
I am wondering, where can you get these grade 10.9 bolts that are M10x1.25? Other threads said McMaster-Carr but when I went there they only have M8x1.25. Does it make a difference? I have been looking all over, do other sizes work or not? Would ACE or Home Depot carry these size bolts? I want to plan ahead and get them because living in Wisconsin with all the salt my bolts are rusted and ****.
Old Feb 27, 2010 | 12:52 AM
egsleepercivic's Avatar
Originally Posted by dandaman15
Reviving old thread
you should be able to get that size at ACE
Old Mar 4, 2010 | 01:27 PM
dandaman15's Avatar
Community Builder
Alright I found the right bolts and bought them but they are threaded the entire 80mm, so does that matter. I realized when I got home that it is not that way oem but I dont think that it matters?
alpinegroove
Nov 18, 2013 01:27 PM
mr_loy
Aug 13, 2009 10:49 PM
twentyhurtz
May 9, 2009 11:41 PM
RTW DC2R
Jun 9, 2006 07:57 PM
shutta
Jan 20, 2006 10:35 AM
