burning a lot of oil
Old May 4, 2006 | 05:28 PM
acura_b18c1's Avatar
Default burning a lot of oil
hey sup all .. i have a 94 gsr with 120k .. did a compression test and got 205-200 -205-205 .. but i notice that i have a lot of oil buildup on my block .. i have some around the area of the distributor and vtec solenoid ... and a lot near where it says b18c1 .. i have some where the IM bolts to the head and also oil on 2 of my spark plugs where the threads are ... i have a straight pipe and when i go WOT, i have A LOT of whitish bluish smoke come out from the muffler .. i dont really think its a big deal..hopefully not anywhere close to needing a rebuild .. just probably a lot of seals i need to replace .. what do u guys think ? .. i go through like 1 quart a week so thats a lot to me .. any help or suggestion would be appreciated
Old May 4, 2006 | 05:36 PM
Johnny Gasparini's Avatar
I didn't ask for a dime.
Default Re: burning a lot of oil (acura_b18c1)
It seems like you need to replace the camshaft seals, the head gasket, and you may have a transmission leak too based on where you are describing.
Old May 4, 2006 | 05:43 PM
s2kdre's Avatar
Default Re: burning a lot of oil (Johnny Gasparini)
ur rings are goin bad, thats a first symptom of blue smoke,
Old May 4, 2006 | 05:53 PM
vesperfx's Avatar
you dont need a headgasket. you probly need a valve cover gasket and
spark plug seals. possibly a cam seal.
the smoke could be a number of things.
could be rings or valve seals.
but if you go through a quart a week i would have it looked at.
Old May 4, 2006 | 05:57 PM
Default Re: (vesperfx)
If he needs new rings, putting a new head gasket is recommended if removing the head from the block, not to mention you could consider it as preventative maintenance. I hope people don't it's ok to reuse their head gaskets.
Old May 4, 2006 | 06:06 PM
ejmatzell's Avatar
Default Re: (Johnny Gasparini)
could be a result of worn down seals... problem could also be the type of oil. 5w-30 full synthetic will leak through those seals, if you're even using this oil.
Old May 4, 2006 | 06:08 PM
vesperfx's Avatar
^^^ you would be very suprised.
alot of people think that they should use the old gasket. i had one guy tell me because it has the same curves exactly as the head. lol
Old May 4, 2006 | 06:23 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Seems like you need quite a few gaskets replaced on the head,
I would say valve seals over rings though, can you Smell the oil when you romp on it?
Also only One quart in one week isn't all that serious, I could burn practically All my oil up before the next change.
Old May 5, 2006 | 07:51 PM
Default Re: burning a lot of oil (FlatBlackTeg)
yea i smell a little oil and a little fuel when i go at it .. yea i highly doubt my rings are the case due to the results of the compression test .. what are all the necessary seals that is suggested to be replaced ?
Old May 5, 2006 | 07:54 PM
Hype-R Stalker
Valveseals, camseal, valvecover set, that's all I can think of for now which is in the head.
And you smell fuel? my o2 was bad and I could smell it quite a bit.
Old May 5, 2006 | 09:39 PM
lalo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnny Gasparini &raquo;</TD></TR><TR><TD CLASS="quote">It seems like you need to replace the camshaft seals, the head gasket, and you may have a transmission leak too based on where you are describing. </TD></TR></TABLE>
Old May 8, 2006 | 10:29 PM
Default Re: burning a lot of oil (lalo)
does the dealer have a set or kit that comes with all the seals and gaskets i need to replace ? ..
and as far as the tranny goes .. what r the neccessary to replace to stop the leak if i do have a leak there ?
Old May 9, 2006 | 04:56 AM
Baron55's Avatar
Can an engine have good compression and still have bad rings? about how does it cost to replace the valve seals?
Old May 9, 2006 | 05:46 AM
Hype-R Stalker
Default Re: (Baron55)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Baron55 &raquo;</TD></TR><TR><TD CLASS="quote">Can an engine have good compression and still have bad rings? about how does it cost to replace the valve seals?</TD></TR></TABLE>
It would probably be bad valveseals if it still had high compression.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acura_b18c1 &raquo;</TD></TR><TR><TD CLASS="quote">does the dealer have a set or kit that comes with all the seals and gaskets i need to replace ? ..
and as far as the tranny goes .. what r the neccessary to replace to stop the leak if i do have a leak there ?</TD></TR></TABLE>
You can probably goto any type of speed shop to get new seals/gaskets,
and it should Probably be cheaper then going directly to the dealer.
I think the one it would be leaking from around the trans is the "Rear main oil seal",
it's something like that, not sure on the exact name though.
That or your Cam seal is just leaking down onto your trans, pics would help.
Old May 9, 2006 | 01:16 PM
Baron55's Avatar
what is the compression for each cyl. on a gsr, 220?
Old May 9, 2006 | 04:21 PM
jtracing919's Avatar
i had a similar problem with my b18c. It had good compression, but would smoke at high rpms. I pulled it apart and found the oil rings stuck on all 4 pistons. Mine was a jdm motor and i've heard that if the oil wasnt changed often enough you get the bronzing inside the motor and such related problems.
Whatislove
Honda Civic (2001 - 2005)
22
May 5, 2010 06:06 PM
ooits34oo
Jul 30, 2006 12:18 AM
mikeym
May 31, 2006 05:48 PM
nhsk84life
Sep 26, 2005 08:13 AM
93lsd
Sep 6, 2004 11:11 AM
