adjusting timing belt tension
Old May 4, 2006 | 04:30 PM
teler86's Avatar
Default adjusting timing belt tension
how do i adjust the tension of a timing belt on a b16 i see the spring and the screw that it connects to, but i can not get a socket on it because the belt is in the way. Is this the wrong screw, or am i doing somthing wrong.
Old May 4, 2006 | 06:06 PM
Crx Jimmy's Avatar
Default Re: adjusting timing belt tension (teler86)
you dont even need the covers off to tension there is a plastic piece that pops out of the cover, i think its a 12 or 14mm head just loosen, turn crank pulley counterclockwise a bit, and the retighten, its self tensioning
Old May 5, 2006 | 07:19 AM
teler86's Avatar
Default Re: adjusting timing belt tension (Crx Jimmy)
all that work for nothing
Old May 5, 2006 | 08:33 AM
EJ1 wilcox's Avatar
In my experience the spring usually doesn't pull the belt tight enough.
So, what I do is remove the spring, hook the end of a hanger through the hole on the tensioner where the spring goes. Then I loosen the tensioner bolt, pull up on the hanger, and tighten the tensioner bolt. Then I rotate the crank 180 degrees and repeat.
Works great, the timing belt is night and tight!
Old May 5, 2006 | 08:48 AM
teler86's Avatar
Default Re: adjusting timing belt tension (EJ1 wilcox)
belt was overtightened problem fixed
Jeffrego
Honda Civic (2001 - 2005)
Oct 31, 2018 05:02 AM
Haleiwa-Brando
Apr 14, 2006 11:17 AM
Finest
Oct 19, 2004 07:34 AM
hon
Sep 21, 2004 03:54 AM
integmester
Jul 2, 2004 05:38 PM
