Valve Adj. Help quicky plz !!
Old May 4, 2006 | 04:24 PM
Elbowpunk's Avatar
Default Valve Adj. Help quicky plz !!
So i got a 91 teg B18 engine.... and im doing a valve adjustment, but the tool the little fittings that show the .008 intake , well where does that go to see if its in that range... ??
Old May 4, 2006 | 05:29 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Valve Adj. Help quicky plz !! (Elbowpunk)
The feeler gauge goes between the cam lobe and the rocker arm.
This link is for the B18C, but your DOHC is quite similar.
http://www.c-speedracing.com/h...t.php
Old May 4, 2006 | 06:23 PM
Elbowpunk's Avatar
Default Re: Valve Adj. Help quicky plz !! (Dogginator)
oo expletive.... i think i did a OPPPS... check it
holy ****.... omg im freaking out... when i was on number 2 LAST ONE trying to tighten, not even that much the ****** thing fell off... how the expletive do i get it back on or did i break it... it doesnt seem to be broken... but holy ****...
PICS
here is the link to the full page i did on AZHT.net... its too long to put in here..
http://www.azht.net/forum/show...29566
Old May 4, 2006 | 07:08 PM
b20integrapower's Avatar
post some pics on here..i cant view them...ill be able to tell u wats goin on if u get some pics
Old May 4, 2006 | 07:21 PM
purplegsr's Avatar
Default Re: Valve Adj. Help quicky plz !! (b20integrapower)
Damn, well that sucks. If you can't pop it back in place, you're gonna have to take the timing belt off, take the cam holders off, and tilt the cam up until you can pop it back in. It's possible you won't have to completely remove the cam if it's cylinder 2, but it's iffy. You should look at redpepperracing.com for the tq specs and pattern for retightening the cam holders, and then also look for the timing belt instructions. You probably won't be able to keep everything at TDC, so when you're putting the tbelt back on, make sure the white mark on the crank pulley is lined up with the mark on the lower timing cover, and that the 2 camgears are also at TDC, and try to loosen the tensioner so you can squeeze the belt back over the camgears without taking everything apart.
Note: the tensioner is on the side of the motor underneath the little black plug, about 6 inches below the camgears. Turn it to the left so you have a little bit of slack on the tbelt. Look at the helms service manual at the site above if you don't know what I am describing.
Good luck man, take your time, and see if you can get a couple of helpers to help you keep everything at TDC when you're messing with the cams while the belt is off, you don't want things to move.
Old May 4, 2006 | 08:54 PM
Elbowpunk's Avatar
ok so this thing :
came off cylinder # 2 intake ... and i cant figure out how to force it back in its proper place..
Yellow square is where it is missing:
on a b18a1 stock motor... 91 integra
was doing a basic valve adjustment when it jsut popped off when i was tightening it...
thanks
Old May 4, 2006 | 09:00 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Your going to have to take off the cam caps and cams to put it on right.
Old May 5, 2006 | 10:16 PM
Elbowpunk's Avatar
Default Re: Valve Adj. Help quicky plz !! (00IntegrAllmotoR)
ok so i tried taking off those 2 bolts that hold the cam in, but after that, that metal that sits on top, wont come off.... any way to get that sucker off ??
Old May 6, 2006 | 07:30 AM
purplegsr's Avatar
Tap them very very lightly with a hammer from the sides, front and back.
Old May 6, 2006 | 11:29 AM
Elbowpunk's Avatar
Default Re: Valve Adj. Help quicky plz !! (purplegsr)
ight thx bro... o and ya..
another F*ed up thing i did...
i striped the cam gear bolt... so how can i get that out ??
Old May 6, 2006 | 11:33 AM
purplegsr's Avatar
you don't need to take out the cam gear bolt, you just want enough room under the cam to slip that rocker back in. You just need to take off the cam holders and tilt it from the cam gear side (leaving the cam gear on) and squeeze it back in.
Elbowpunk's Avatar
well... to do TDC i need to use the bolt.... and i cant right now
lol ...
Old May 6, 2006 | 11:47 AM
purplegsr's Avatar
Oh, i see what you're saying, damn, that sucks. So you didn't strip the bolt threads, you rounded the head of the bolt so you can no longer turn it?
If you get a glove and just grab the whole thing, you should be able to move it by hand. Then put a pin punch (grab a drill bit or something or a 5mm allen wrench) in the TDC hole on the cam and holder. If that doesn't work, try to file the edges of bolt flat again so a smaller socket will fit on. I wouldn't hammer on a smaller socket either, I would be worried about all that smacking of the valve train.
yeesh, sorry man, you're having some terrible terrible luck.
Old May 6, 2006 | 12:16 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elbowpunk &raquo;</TD></TR><TR><TD CLASS="quote">well... to do TDC i need to use the bolt.... and i cant right now
lol ... </TD></TR></TABLE>
you can get a crecent wrech and move it , theres is a area on the cams by the first cylinder for a wrench.(it goes around the cam)
looks towards cyliner 1
Old May 6, 2006 | 12:48 PM
purplegsr's Avatar
Default Re: Valve Adj. Help quicky plz !! (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">you can get a crecent wrech and move it , theres is a area on the cams by the first cylinder for a wrench.(it goes around the cam)
looks towards cyliner 1</TD></TR></TABLE>
good call
Old May 6, 2006 | 02:25 PM
Elbowpunk's Avatar
i jsut tryin the hammer tapping... for liek 15mins.... that **** aint moving... DAMIT
Old May 6, 2006 | 05:10 PM
purplegsr's Avatar
Default Re: (Elbowpunk)
you should be able to tap it from each side, then wiggle it with your hand and pull up at the same time.
Old May 6, 2006 | 05:19 PM
jgalaz1's Avatar
why don't you just call Acurazor from AZHT and have him come out and help you. He offered to go to your house, but you were too busy. Sounds to me like you could need it. You should do it before something else get's broken.
lude98SH
Apr 8, 2009 02:57 PM
gsr96cx
Aug 25, 2008 12:45 PM
hitvtecgetloud09
Jul 10, 2006 03:22 AM
mickey513
Feb 27, 2004 08:41 PM
SuperMan19
Nov 29, 2001 07:55 AM
