Cali + Engine build + OBD2 + Smog = ?
Old May 4, 2006 | 03:07 PM
leira619's Avatar
Default Cali + Engine build + OBD2 + Smog = ?
Okay... first off I'd like to say that I'm in Cali... where smog = So, with this said, this is more for the Cali heads. I was curious how to pass smog (when it's due) if you have an OBD2 car w/ a mild to aggressive engine build using Hondata, Crome, Uber, etc.? If you have a mild build on the engine, do you simply plug in your original OBD2 ECU and go for a smog? I'm curious to know because I plan on purchasing some goodies for my girl, but want to be prepared when that time comes to smog. Some info on this matter would be great. Thanks.
Old May 4, 2006 | 03:17 PM
dom93hatch's Avatar
There was a thread a while ago where someone figured out a way to toggle between programmed race maps and stock maps. That could be one way.
Or you could swap in a stock motor, get it approved, and then put your built motor back in
Old May 4, 2006 | 03:38 PM
jtchinoy's Avatar
find a friend who does smog.
Old May 4, 2006 | 03:48 PM
dkim48's Avatar
Default Re: Cali + Engine build + OBD2 + Smog = ? (leira619)
if it is the original motor that belongs in the car it is easy to pass. if it is a hybrid then it needs to be bar'd first then it's easy. what do you have in mind for a mild build?
Old May 4, 2006 | 04:18 PM
leira619's Avatar
Default Re: Cali + Engine build + OBD2 + Smog = ? (dkim48)
Well, this is what I've got:
Skunk2 Stage 1 cams
Skunk2 IM
Cam gears
JDM ITR pistons
DC JDM 4-1 header
Greddy Cat-back exhaust
AEM CAI
JG Redline Series head w/ PnP and upgraded valvetrain
J's lightened flywheel
ACT clutch
Chipped P28 ECU
My car is a 96 Integra GSR. I plan on swapping out my cams with something a bit more aggressive; getting a better header (Rage, Hytech, SMSP... jus' something better than what I have); Hondata or Crome; and of course, a good tune. My goals are to get in the 200-210 whp range.
Old May 10, 2006 | 07:54 AM
TEST ONLY's Avatar
Default Re: (jtchinoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jtchinoy &raquo;</TD></TR><TR><TD CLASS="quote">find a friend who does smog.</TD></TR></TABLE>
[b] X 2 ...
Old May 10, 2006 | 12:13 PM
jtchinoy's Avatar
Going to reitterate find a friend who does smog.
I was just on the AEM/ DC sports site. Any JDM spec parts, particularly that JDM header you're putting on, doesn't pass CARB standards, thus illegal in california. You can pray the smog guy won't auto fail you for it, but if he's an *** you'll fail the visual test.
Old May 10, 2006 | 02:00 PM
strsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leira619 &raquo;</TD></TR><TR><TD CLASS="quote">Well, this is what I've got:
Skunk2 Stage 1 cams (i have)
Skunk2 IM (i have)
Cam gears (I have)
JDM ITR pistons (stock, at 10.8:1 CR on my b16)
DC JDM 4-1 header (have RMF)
Greddy Cat-back exhaust (have apex)
AEM CAI (have)
JG Redline Series head w/ PnP and upgraded valvetrain (alaniz)
ACT clutch
Chipped P28 ECU (hondata)
My car is a 96 Integra GSR. I plan on swapping out my cams with something a bit more aggressive; getting a better header (Rage, Hytech, SMSP... jus' something better than what I have); Hondata or Crome; and of course, a good tune. My goals are to get in the 200-210 whp range.</TD></TR></TABLE>
Check the quote. I have almost everything u have. My car passes smog. All u need to do is put on a stock or CARB approved header, plug in the stock ecu and u should b ok. Thats all i do. I guess u may possible need to zero out the cam gears. Also put the timing back to stock, 16 degrees i think.
Of course it depends on the car too. Some motors just pollute more then others, even in stock form, depending on the condition of the motor & its smog equiptment. But if everything is in good condition u should be ok.
Old May 10, 2006 | 02:23 PM
emotionisdead's Avatar
Very Emergency!!
sorry to say, put your gonna have to get rid of the obd2 **** if you wanna tune it. i'm a smog tech in nevada and if an obd2 car doesn't have the right obd2 computer to connect to the smog machine, failure. i'm sure california is the same way, if not stricter. just get a po box in an outlying area that doesn't require smog and register your car to that address. or get a friend that does smogs.
Old May 10, 2006 | 02:41 PM
strsi's Avatar
Default Re: Cali + Engine build + OBD2 + Smog = ? (emotionisdead)
I've considered that before. I guess there are certain areas, i think mostly in northern cali, that dont require smog.
But yea, u can run hondata or what ever else on an obd1 ecu w/ a conversion harness. & then for smog just unplug it & plug in the stock obd2 ecu.
Old May 10, 2006 | 03:11 PM
Very Emergency!!
Default Re: Cali + Engine build + OBD2 + Smog = ? (strsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strsi &raquo;</TD></TR><TR><TD CLASS="quote">I've considered that before. I guess there are certain areas, i think mostly in northern cali, that dont require smog.
But yea, u can run hondata or what ever else on an obd1 ecu w/ a conversion harness. & then for smog just unplug it & plug in the stock obd2 ecu.</TD></TR></TABLE>
along with all the other bullshit obd-2 sensors that the obd1 computer ignores. if i were you, come smog time i would put the stock cams, exhaust manifold, exhaust w/ stock cat, stock airbox, stock injectors in and then plug your obd2 computer in, drive it for a week or so, THEN go to the smog statio if the check engine light hasn't come on by that time.
Old May 10, 2006 | 03:49 PM
( o )( o )'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emotionisdead &raquo;</TD></TR><TR><TD CLASS="quote">
along with all the other bullshit obd-2 sensors that the obd1 computer ignores. if i were you, come smog time i would put the stock cams, exhaust manifold, exhaust w/ stock cat, stock airbox, stock injectors in and then plug your obd2 computer in, drive it for a week or so, THEN go to the smog statio if the check engine light hasn't come on by that time.</TD></TR></TABLE>
that's pretty much exactly what i did last week. converted EVERYTHING back to stock obd2 on my 00Si. (except for the ctr cams/pistons/maxbore'd TB/aem cai) i drove around to set the readiness codes, which only takes 10 minutes if done properly. as long as you set 3 of 4 readiness codes and have no CEL's you should pass.
Old May 10, 2006 | 04:50 PM
TEST ONLY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emotionisdead &raquo;</TD></TR><TR><TD CLASS="quote">[b]get a friend that does smogs.</TD></TR></TABLE>
jr408
Feb 23, 2008 03:40 PM
ALLMOTOR CRX
107
May 23, 2007 01:52 PM
Wazup
Feb 16, 2004 02:25 AM
TypeRInNeed
Jan 6, 2002 10:07 PM
