whining sound from freshly installed motor
Old May 4, 2006 | 01:28 PM
teler86's Avatar
Default whining sound from freshly installed motor
like the title says my motor makes almost like a supercharger whine when reved what could it be, i heard that the timing belt might be too stiff, but how stiff should it be, or i heard that the tensioner pully might have a bad bearing what do you guys think.
Old May 4, 2006 | 01:40 PM
teler86's Avatar
Default Re: whining sound from freshly installed motor (teler86)
i wanted to subscribe to bump
Old May 4, 2006 | 01:55 PM
94eg!'s Avatar
#1 Super Guy
Loved
Yes that sound most likely has something to do with the timing belt. My wifes accord started making that noise after a timing belt change. Honda told us the noise wan't necissarily bad, but it isn't good either. They told me it is most likely rubbing on somthing to make that sound (accord has two timing belts). The only problem is that you cannot really get in there to check it out without taking the DAMN crank pulley off. That seems to be one of the more difficult things to do (I couldn't get mine off to save my life).
It is possible to pay a mechanic to break loose the bolt for you and then tighten it back down. Then when you get home, you can take it off easily. Just a suggestion...
Old May 4, 2006 | 02:28 PM
teler86's Avatar
Default Re: whining sound from freshly installed motor (94eg!)
well the crank pulley is easy for me good ol impact, but do you guys think its over tensioned or the bearing is bad?
Old May 4, 2006 | 03:33 PM
Crx Jimmy's Avatar
do you have AC? when the AC idler pulley goes bad thats the sound it makes, remove or cut off the belt (thats what i did since the AC didnt work anyway),
Old May 4, 2006 | 03:35 PM
teler86's Avatar
Default Re: whining sound from freshly installed motor (Crx Jimmy)
i do not have ac i only have an alternator
Old May 4, 2006 | 07:15 PM
94eg!'s Avatar
#1 Super Guy
Loved
Since the tensioner is "spring" loaded, there really isn't any way for it to be over tensioned. Your just supposed to set the motor at TDC, loosen the tensioner bolt, turn the motor forward 3 cam teeth, and retighten the bolt. If the tensioner spring is bad at the time of the tensioning procedure, then it could definenlty be "under-tensioned"...
Old May 4, 2006 | 07:24 PM
EJ1 wilcox's Avatar
Mine whines a bit, but I don't really worry about it. I'm pretty sure it's my timing belt. I tensioned it using the good old, "coat hanger" method. Because when I tensioned the belt according to the manual the belt was too loose and the teeth got chewed up within a few thousand miles.
I'm not making that mistake again, I tightened the **** out of that thing. It makes a bit of a whine, but it's not that loud and I keep an eye on my timing belt anyways, so if it starts to wear funky, I'll loosen it up a bit. But from what I've read, it's okay to have your timing belt tight.
Old May 4, 2006 | 08:26 PM
statik121's Avatar
How about just loosening up your accessory belts a tad. I've seen that many a times and have done it myself. (last week as a matter of fact on an Oddessey) Do one at a time to determine which one it is. If one starts to squeel its too loose. OHpe that was helpful.
Old May 4, 2006 | 08:29 PM
statik121's Avatar
Almost forgot, rule of thumb for timing belts is you should be able to twist it about 90 degrees on the longest section between 2 pulleys under tension. Thats a good yardstick for tension if your not sure.
Old May 5, 2006 | 04:53 AM
spiceisler's Avatar
Default Re: (statik121@hotmail.com)
Alternator dude! Mine does the same thing.
Old May 5, 2006 | 05:47 AM
teler86's Avatar
well it is definatly not the alternator because i disconnected it the belt and then started the motor the sound did not go away, but thanks, so can the timing belt be too tight?
Old May 5, 2006 | 05:53 AM
YasRex's Avatar
Default Re: (teler86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teler86 &raquo;</TD></TR><TR><TD CLASS="quote">well it is definatly not the alternator because i disconnected it the belt and then started the motor the sound did not go away, but thanks, so can the timing belt be too tight?</TD></TR></TABLE>
sounds like the only thing besides the pulley
Old May 5, 2006 | 05:57 AM
crxluv2's Avatar
Transmission?
Old May 5, 2006 | 07:18 AM
teler86's Avatar
Default Re: (crxluv2)
no its definatly comming from the belt side
Old May 5, 2006 | 08:48 AM
teler86's Avatar
belt was overtightened problem fixed thanx guys
Old May 5, 2006 | 12:58 PM
statik121's Avatar
Which, belt?
Old May 5, 2006 | 02:18 PM
teler86's Avatar
timing
accord96lx
Mar 9, 2014 04:43 AM
FOXxX
Jul 28, 2013 05:38 PM
nogutsnoglory77
Apr 17, 2009 10:47 AM
Benhawk
Jan 18, 2008 04:40 AM
tub_sephiroth
Aug 8, 2003 10:53 PM
