A/C Question
Old May 4, 2006 | 01:23 PM
1990AccordEX's Avatar
Default A/C Question
My '90 Accord A/C compressor lock up so i went to the junk yard and pick up one. i went to a shop and the guy told me to make sure that their is oil in the compressor if this is true what kind of oil and how much.
Old May 4, 2006 | 03:08 PM
accord-pro's Avatar
Default Re: A/C Question (1990AccordEX)
go to your local parts store and get a small bottle of a/c oil for R-12 system.. assuming a/c system has not been retrifitted to accept R134A.., it only takes 2-3 oz of oil.. Also i would advice that you replace the receiver drier ..... and then evac + recharge ..
Old May 4, 2006 | 04:10 PM
blueshark's Avatar
Default Re: A/C Question (accord-pro)
Again accord-pro is right! But I reccomend a R134A conversion and the installation of a ultraviolet dye to find any possible leaks. R12 will break your wallet!
Old May 4, 2006 | 05:09 PM
Ross 2.0's Avatar
In a Junkyard near you.
I reccomend Honda PAG oil. And yes most definately replace the reciever drier. Even if the a/c worked at this age it's a good time to go ahead and do it
Old May 4, 2006 | 08:59 PM
Default Re: (MooGoCow3)
thank you for all the help
Old May 4, 2006 | 09:02 PM
Default Re: (1990AccordEX)
what is involve to convert my old R-12 to R-134A and the estimate cost of doing that Thanks
Old May 4, 2006 | 11:07 PM
blueshark's Avatar
Honda sells the conversion kit which includes the Honda PAG oil that MooGoCow recommended, Also has the fittings but no refigerent. Not real expensive but you'll need a A/C licensed tech to do the evacuation and recharge. (Don't forget the dye, It will save you in the long run)
Old May 4, 2006 | 11:16 PM
YeuEmMaiMai's Avatar
I would NOT do a r143a conversion on these cars. The R12 system os barely sufficient if you live in a extremely hot area. You will be way better off properly repairing the system and refilling it with r12
RFalcoCTI
Honda CR-V & Element
Mar 23, 2017 12:15 PM
all-mtr-teg
Mar 8, 2008 06:11 PM
colvin84
Jan 21, 2008 03:50 PM
MiniMee
Jul 24, 2006 10:04 AM
sonicrex
Jan 21, 2005 01:27 PM
