Timing light gives two different readings
Old May 4, 2006 | 01:21 PM
hondapwr's Avatar
Default Timing light gives two different readings
Ok, here's the scenario:
If I set the timing advance on the timing light to zero, I read 15 degrees advance (pointer aligns slightly before the red mark)
If I set the timing advance to 15 on the timing light, it doesn't quite line up with the white TDC mark. Setting the timing advance to 17 on the timing light makes the TDC mark line up.
So which is the correct reading? 15 or 17? Has anyone else had this problem?
Old May 4, 2006 | 01:57 PM
Relic1's Avatar
which side of the 16* mark is the zero setting showing agian?
towards the 16* mark?
Old May 5, 2006 | 06:08 AM
hondapwr's Avatar
Default Re: (Relic1)
The timing pointer aligns between the 14 and 16 mark with the timing light set to zero.
Old May 6, 2006 | 08:26 AM
hondapwr's Avatar
Default Re: (hondapwr)
Anyone?
Old May 6, 2006 | 08:33 AM
DELTEGRA's Avatar
Default Re: Timing light gives two different readings (hondapwr)
What kind of timing light is it?
Old May 6, 2006 | 09:22 AM
Luserkid's Avatar
Default Re: Timing light gives two different readings (DELTEGRA)
Are you jumping the ecu?
Old May 8, 2006 | 08:17 AM
hondapwr's Avatar
Default Re: Timing light gives two different readings (Luserkid)
Yes, I'm using a jumper to keep the timing steady at about 850rpm according to my VAFC.
It's a summit racing timing light. I guess I could try to find someone else with a timing light and compare readings.
efdxjdm
Oct 1, 2009 08:27 AM
rnbguy
Aug 15, 2007 02:47 AM
xJDMCx
Sep 15, 2006 09:34 AM
AggAccord03
Jul 7, 2004 06:16 AM
Jimmy L
Aug 21, 2001 01:14 PM
