Need help on a possible spark plug wire going bad issue.
Old May 4, 2006 | 11:59 AM
djdc2's Avatar
Default Need help on a possible spark plug wire going bad issue.
I know that's a strange topic heading...but I really didn't know what to call it.
I have a 94 RS. Up until last month My car starts to accelerate irradically. I always drive by low reving. But now...when i accelerate...I can feel like the car sputters....and then suddenly jolts forward even when I have my foot steady on the gas.
So acceleration has been a problem with me recently...the problem stops after 3000+ RPM. Now one of my coworker's Hummer just got checked out and he had the same type of problem...and his mechanic told him it was spark plug wires.
I haven't changed the wires since I bought it last year.
Can anyone help.
Old May 4, 2006 | 12:02 PM
teg racer 877's Avatar
Default Re: Need help on a possible spark plug wire going bad issue. (djdc2)
do you have a mutimeter? check resistance on the wires, I doubt thats the problem tho, sounds like you need a tune up.
Old May 4, 2006 | 12:12 PM
djdc2's Avatar
Default Re: Need help on a possible spark plug wire going bad issue. (teg racer 877)
I sure do...can you tell me what to detect?
I know you're suppose to check for Ohms...so if there is resistence that meanns there's no break...but if it read zero...then we have a broken wire. But what is it's broken....but only a small section?
Old May 4, 2006 | 01:00 PM
It should read like 5 ohms per foot or something I dont know for sure.
Old May 4, 2006 | 03:43 PM
djdc2's Avatar
OK, will check for 5 ohms per feet.
Old May 4, 2006 | 08:33 PM
dc5_integra's Avatar
A buddy of mine had almost the same problem with his. The spark would go down the wire and out the side and arc onto another wire because it had a hole in it. Bought new ones and works fine.
LawlessOne
Mar 13, 2012 12:35 AM
dabeast111
Jun 5, 2011 08:43 PM
MyHotsh
Jun 5, 2009 04:27 PM
jpnucrx
Jun 17, 2006 09:44 AM
yamahama
May 13, 2004 11:37 AM
