Crx dx to b18b
The motor is an 0bd1 first off! Where can I find info on this swap? I need to convert it to 0bd0 so what distributor, ecu plus changes in the wiring harness besides the dual to multi port injection!
Are the plugs other than the injector plugs going to hook right up to the b18b. Using the dx ecu. Is the wiring going to be exactly like the dx to si conversion. I will be using the pr4 and the obd0 ls distributor.
Basically is the general swap guide from dx to si, dpfi to mpfi the same as for dx to obdo ecu and distributor b18b. Also changing the distributor and ecu are the only things needed to convert this to obd0.
flatblk
Aug 13, 2005 03:41 AM
shorty91
Jun 23, 2003 11:51 AM
