Knock sensor trouble. *searched*
Old May 3, 2006 | 09:30 PM
co_OlLo_OdDo_Od's Avatar
Default Knock sensor trouble. *searched*
Hi, it seems like something such as this would have been covered, but..
"No Results Found
Your search for knock sensor returned no results."
Anyway, I have code 23 which is the knock sensor. My Cel comes on at the exact instant my cars temperature bar is half way full, not one moment before. It's starting to bother me. I know knock sensors detect engine knock long before you can hear it, and then retard the spark timing to prevent further knocking. How do I know for sure if my sensor is broke or if it is finding a knock and is trying to alert me of it by throwing the Cel? I am noticing a slight drop of low-end power and overall power since this has happend, and I read somewhere that the knock sensor can cause this. Is there anyway to tell other then the obvious "if you hear a knock"? Doesn't the sensor, when it notices a knock, roll the timing back until it stops? .. as if it's supposed to fix itself. If that were true, a Cel wouldn't pop right, cause it fixes itself. I'm so confused on what I can do. If you have any info on what I can do, please.. I'm all ears. Thanks so much if you can help. Btw, it's a 95 si. Thanks again.
Old May 3, 2006 | 10:22 PM
Hawkze_2.3's Avatar
Default Re: Knock sensor trouble. *searched* (co_OlLo_OdDo_Od)
The knock sensor is right above the oil filter and under the intake manifold....get under there and check it out.
Old May 3, 2006 | 11:36 PM
sharkcohen's Avatar
Code 23 doesn't emerge if you have knock. You get this code if there's something wrong with your knock sensor.
98vtec
Aug 18, 2006 07:12 PM
DumpedSi
Aug 10, 2003 08:30 PM
brian b
Aug 30, 2002 03:10 PM
