need help ITR or CTR pistons
Old May 3, 2006 | 06:40 PM
Orange Eg6's Avatar
Default need help ITR or CTR pistons
alrights now i need some help i know that if i use ITR's in a gsr you will get 11 5 compersion and if you use CTR's you get 12 1. Ok its obvious i will get more power using CTR pistons but some people have told me i might have to worry about valve clearence. Should if say F*&% it and use CTR's or stay safe and use ITR's someone help me out
Old May 3, 2006 | 07:51 PM
SkoundrelUSA's Avatar
cute little bastard
Default Re: need help ITR or CTR pistons (Orange Eg6)
Here's some help links. I'm not sure which calculator is more accurate but at least it'll give you an idea
http://technet.ff-squad.com/cr-calculator.htm
http://www.c-speedracing.com/h...c.php
And here's a little info on B-series pistons and suggestions
http://www.ff-squad.com/tech/temp/pistons.htm
Old May 3, 2006 | 08:28 PM
hapexamendios 2.0's Avatar
R.I.P.
what motor is it going in?!??!
Old May 3, 2006 | 08:59 PM
jadugartir's Avatar
Default Re: need help ITR or CTR pistons (honda 3300)
use b16, its not as aggressive as the ctr but still better than itr, and prolly cheaper, and more readily available. As far as i know you wont worry about valve clearance.
GSR_hatch936
11
Jan 10, 2008 12:06 PM
96-LSvtec
May 12, 2005 08:40 AM
arielmalespin
Jan 13, 2005 07:38 PM
lemongreenhatch
Jun 6, 2004 06:58 PM
pinota
May 20, 2002 06:30 PM
