putting rsx seats in a eg hatch: need help ASAP
Old May 3, 2006 | 05:09 PM
mexicanstud's Avatar
Default putting rsx seats in a eg hatch: need help ASAP
i just got rsx seats for my eg hatch, obvioulsy the rsx rails dont match the stock eg seat bolt pattern. Can i use my stock eg rails and just the rails or everything on the bottom of the seat. If anyone can tell me what exactly is needed for it to fit right
Old May 3, 2006 | 05:15 PM
y2kferari's Avatar
Default Re: putting rsx seats in a eg hatch: need help ASAP (mexicanstud)
no, don't try detaching the rails to swap over. I found that the hard way from going from a 93 seats to 99 SI seats. The bolt pattern(from the rail to the seats) are prolly different. Drill new holes I would suggest. Unless u want to take them apart and see if the bolts match up, they MIGHT. good luck
Old May 3, 2006 | 06:05 PM
postman's Avatar
make plates that adapt new rail to old hole. hah, thats what i told her
Old May 3, 2006 | 06:06 PM
anyone else?? pics would be helpful on what to do exactly
Old May 3, 2006 | 08:14 PM
Dj-KSwift87's Avatar
Default Re: (mexicanstud)
Just get new plates for the ends of the old rsx rails and weld them on. Then line the plates up to the existing holes and make marks to were they go. then drill the holes in and line them up and bolt em in. RSX seats in EG. There is a good thread on this. ill look and repost. good luck with it. Im fixin to swap em in my Ek.
Old Jun 22, 2006 | 08:02 PM
WARCOVENANT's Avatar
Default Re: (Dj-KSwift87)
we did them in a del sol. 3 bolts lined right up and we just bent the other one so the seat sat level.. it worked out perfect.
Old Jun 22, 2006 | 08:14 PM
prison_snitch's Avatar
yea like they said just get some peices of metal and jb weld it
Old Jun 22, 2006 | 08:21 PM
Sleepy_Red_hatch's Avatar
Default Re: (prison_snitch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prison_snitch &raquo;</TD></TR><TR><TD CLASS="quote">yea like they said just get some peices of metal and jb weld it</TD></TR></TABLE>
oh god, do NOT jbweld a seat bracket.....EVER this can and WILL kill you in an accident
Old Jun 22, 2006 | 08:31 PM
SidewayzSupra's Avatar
Just go to a local welding/metal shop and ask them to make you some brackets. won't run you that much.
That's what i did.
Old Jun 22, 2006 | 08:35 PM
CBEengineering's Avatar
Default Re: (SidewayzSupra)
was th RSX/ep3 available with cloth??
Old Jun 22, 2006 | 08:59 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Default Re: (CBEengineering)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBEengineering &raquo;</TD></TR><TR><TD CLASS="quote">was th RSX/ep3 available with cloth??</TD></TR></TABLE>
Yes, the base model Rsx.
Old Jun 23, 2006 | 05:00 PM
Default Re: (INVALID)
ok thanks
ANNiHiLATORS
Aug 26, 2012 12:23 PM
EG-tofu
Jul 1, 2007 04:51 PM
preludedriva
Mar 26, 2007 10:13 PM
egjoe
15
Aug 28, 2003 07:52 AM
